C5 Rear Upper control arm mounting points
Unfortunately this diagram provides limited info for the rear upper control arms. It looks to me that datum "M" is defining the forward surface of the rear upper control arm forward bushing as 1in Aft of the suspension cradle rear mounting hole center. This will at least give me a starting point.
First things first, Can anyone confirm that I am interpreting the diagram correctly? If you think that I am incorrect, can you please clarify what datum "M" defines?
Next can anyone please tell me the following:
Are the rear suspension cradle mounting surfaces level to the ground?
What is the angle that the rear upper control mounting points are set to? In other words of you drew an imaginary line through the center lines of the rear upper control arm mounting bushings, what angle would this line be to the ground? It seems that it is very close to flat, approximately 1 deg off from flat.
I'd appreciate any info that you can provide. FYI, I have a build thread for my Camaro project on Pro-touring forums if your interested in seeing C5 suspension in a 1st gen fbody.
https://www.pro-touring.com/threads/...7-Camaro-build
Cool project. It's a ton of work but awesome when it's done.
Here's mine
https://www.corvetteforum.com/forums...different.html
