Starting issues
Old Aug 14, 2020 | 01:08 PM
tcstaples's Avatar
tcstaples
Default Starting issues
2003. Hadn’t started it for about 3 weeks. Had to charge it to get it started. Drove it most of the day shutting it down about 6 times no issues starting. Battery is only about a year old. I have a volt reader and it was showing 13.2 or so most of the day. Put it on a Ctek charger over night. Wouldn’t turn over next day. Charged the battery at 55 amps for a few hours then 2 amps over night and wouldn’t start the next day. Does this sound like a ground issue? The ignition switch has been replaced
Old Aug 14, 2020 | 02:46 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Is this a no crank no start ??...could be starter issue....hard to tell exactly what it may be !!
Old Aug 14, 2020 | 03:35 PM
tcstaples's Avatar
tcstaples
It starts to turn over then it starts clicking like a dead battery. Can’t believe the battery is bad enough it won’t take a charge enough to start
Old Aug 14, 2020 | 04:29 PM
C5 Diag's Avatar
C5 Diag
I don’t know if you are using a DVOM to test the condition of the battery but if that’s low and you can’t charge it to at least 12.66 it’s probably a bad battery...take the battery to your friendly automotive box store and see if they can test it for you !!
Old Aug 14, 2020 | 04:31 PM
mmartinez's Avatar
mmartinez
It's your battery, not taking a charge, starts to turn over, and then starts clicking, but to make sure pull your battery take it to your nearest auto parts store and have them charge and load test your battery.
Old Aug 14, 2020 | 09:41 PM
tcstaples's Avatar
tcstaples
Had the battery tested and after charging it all night when they tested it it was near 0. Only a year old but must have been in bad shape to not even take a charge. They replaced it and I installed it and fired right up. Still going to check all the grounds and starter connections. Alternator putting out what it should. Thanks for the help
Old Aug 15, 2020 | 08:34 AM
c4gone's Avatar
c4gone
Awesome news that it worked! Just keep testing it out and throw us an update
To Starting issues
