Key Fob will not reprogram...
Old Nov 30, 2002 | 04:14 PM
Trey395's Avatar
Trey395
Default Key Fob will not reprogram...
I recently purchased a '99 FRC. The car did not come with transmitters. I have since purchased one and tried to program it to the car with no luck. The transmitter is brand new and was supposedly tested on a '98 with no problems. I've tried replacing the battery with no luck. I also checked and double-checked that the procedure I was going through was correct. I get all the way to the "Press LCK+UNLCK" but after holding the buttons on the remote for well over 15sec. I get nothing.
Does anyone know what might be wrong? Are there any situations where the PCM will not let you reprogram the key fobs?
Old Nov 30, 2002 | 06:46 PM
RWhite's Avatar
RWhite
Default Re: Key Fob will not reprogram... (Trey395)
I had a similar problem in trying to program a new key fob for my '98 Explorer yesterday. The Ford manual directions would not work!!
I went to Google and searched for directions. Seems like the manual was incorrect in the number of times you turned the ignition key on and off (part of the progarmming procedure). Not sure what the procedure is for a Vette.
Good luck!
Old Dec 2, 2002 | 10:45 AM
Trey395's Avatar
Trey395
Default Re: Key Fob will not reprogram... (RWhite)
I obtained instructions from 3 different places (dealer, manual, and here) and all had the same procedure.
Somebody has to have a suggestion?
Old Dec 2, 2002 | 02:10 PM
C5Noir's Avatar
C5Noir
I replaced the battery in my fob, did the relearn and resync and it still doesn't work. I get two honks and the doors cycle b/w lock/unlock twice. Any help is greatly appreciated. Thanks.
Old Dec 2, 2002 | 02:59 PM
Trey395's Avatar
Trey395
Default Re: Key Fob will not reprogram... (C5Noir)
I'm wondering if pulling the battery for a couple minutes might work? Maybe get the PCM to forget whatever it has in it.
Old Dec 2, 2002 | 03:08 PM
C5Noir's Avatar
C5Noir
Good idea, this all started after I poulled my battery out to remove some wiring! I'll go try it!
Old Dec 2, 2002 | 04:16 PM
C5Noir's Avatar
C5Noir
The removal of the negative battery cable and reconnection after 15 minutes cured the problem ;). Thanks for the suggestion!
Old Dec 2, 2002 | 05:56 PM
C5Noir's Avatar
C5Noir
Nevermind, it stopped working again :mad
Old Dec 2, 2002 | 06:45 PM
PaceThis's Avatar
PaceThis
My guess is that you have the wrong transmitters...someone sells these on eBay as 97+ fobs, but they're only good on 01+'s...easy way to check...does it have a switch for active/passive entry? If not, it's not the right one for your car...the one for your car is much more expensive and bigger...
Old Dec 2, 2002 | 11:41 PM
Trey395's Avatar
Trey395
Default Re: Key Fob will not reprogram... (PaceThis)
Mine has the active/passive feature... I also tried the battery trick and had no luck, still no honk. :mad
[Modified by Trey395, 11:14 PM 12/2/2002]
Old Dec 3, 2002 | 10:13 AM
weaver's Avatar
weaver
It's easy for the contacts in the fob to bend and not make good contact with the battery. Open the fob and insure that they are making good contact with the battery. Be gentle, they are also easy to break off.
Old Dec 3, 2002 | 03:13 PM
vetteboy2k's Avatar
vetteboy2k
Default Re: Key Fob will not reprogram... (weaver)
If you have a little volt meter check that your getting 3 volts on the 2 little contacts from the battery. Also check that when you put the fob together again that the contacts touch the pads on the otherside. I had to bend mine slightly to get everything to work.
Hope that helps some. :thumbs:
Old Dec 3, 2002 | 04:21 PM
StickTail's Avatar
StickTail
Default Re: Key Fob will not reprogram... (vetteboy2k)
I got my 99 and the FOB did not work. I though it was the battery and replaced that...nothing. I then went and bought 2 more FOBs on ebay for over $100. Then one night I was messing around with my original and decided to pull out the volt/ohm meter. I was able to "fix" it by inserting a piece of paper under the battery on the side to insulate what seemed to be shorting the circuit. I now have 3 FOBs. I will sell one of the extra ones I bought (not the one I fixed) for $50+shipping if you need it.
-Brian
Old Dec 3, 2002 | 05:51 PM
Trey395's Avatar
Trey395
Default Re: Key Fob will not reprogram... (fdupny)
Brian - If I can get one to work I will probably take you up on it. I'm having enough problems as it is though :)
I tried playing with the connectors, I'm sure they are making contact and I have a new battery. I broke out the digital multi-meter and everything looks ok. Any other ideas?
If there was a problem with the receiver, would it throw a DTC code?
[Modified by Trey395, 5:04 PM 12/3/2002]
Old Dec 3, 2002 | 06:04 PM
C5Noir's Avatar
C5Noir
Trey, I'm in the same boat. Can you get yours to learn to the car? When I get mine learned it does 2 honks instead of one and the fob still will not work.
Old Dec 3, 2002 | 06:14 PM
StickTail's Avatar
StickTail
Trey,
I can send you one I know for a fact works.
If it works for you you can shoot me some green back.
If not just send it back and troubleshoot your car further.
Let me know if I can help.
Good luck
-Brian :cheers:
Old Dec 3, 2002 | 07:03 PM
Trey395's Avatar
Trey395
C5Noir - I don't get any honks, just the "Press LCK+UNLK" message...
fdupny - I think I will take you up on that offer. I'll send over my address when I get to a machine with my email on it.
I just thought of one way to verify that it might be the FOB after all... What is the FCC id on the back of your transmitter for the '99s? I'm looking at AB00216T. I think this changes with the model year.
[Modified by Trey395, 6:06 PM 12/3/2002]
To Key Fob will not reprogram...
Old Dec 3, 2002 | 08:10 PM
kraff's Avatar
kraff
Hmm. FWIW, mine has that same number, does not have an active/passive switch, works on my car (needs relearned a lot) and I have a 2000.
Good luck :cheers:
Old Dec 3, 2002 | 10:52 PM
StickTail's Avatar
StickTail
[QUOTE]I just thought of one way to verify that it might be the FOB after all... What is the FCC id on the back of your transmitter for the '99s? I'm looking at AB00216T. I think this changes with the model year.
QUOTE]
All 3 of mine are AB00216T
Old Dec 4, 2002 | 10:25 AM
rhoeven's Avatar
rhoeven
QUOTE]
I just purchased a new fob for my '99 and the numbers are: FCC AB00216T and the GM part # is 10253839
Both are printed on the back of the fob.
Hope this helps.
Roger
