Need Your Opinions Please
Old Aug 20, 2020 | 04:01 PM
raulg4id@gmail.com's Avatar
raulg4id@gmail.com
Cruising
Default Need Your Opinions Please
Hello,
the ECBM unit in my 2000 C5 is shot. After 20 years with my Vette, wondering if it's time to part with it. It's value is right around 10k and it would cost between 2-3k to get a refurbished ECBM unit put in. Not convinced the cost of the repair is worth it considering the value of the car. Would welcome your opinions. Thank you
Old Aug 20, 2020 | 05:40 PM
knewblewkorvette's Avatar
knewblewkorvette
To the best of my knowledge, the 2000 ECBM cannot be repaired. You can get a used one off eBay, prices vary on what module you have, either a V or M. If you have a M, there are currently two of them for under $1,000 The V, damn, $1,800
Personally, if I had the M version I'd fix it with a used one. If I had a V one, I'd hunt for one (keep a eye on eBay, call recyclers of C5s like Vettenuts) I have two 99s and someday I too might be in your shoes. If mine went bad, I would NOT sell it. Several of my other vehicles don't have traction control. Even without abs, the Vette would stop way quicker than say my Ford Expedition with abs. Just because the ECBM goes bad doesn't mean you can't drive a C5 as is.
Old Aug 20, 2020 | 05:45 PM
Mickeyrx70's Avatar
Mickeyrx70
Good advice ... anti skid is nice, but not necessarily a show stopper.
Old Aug 20, 2020 | 06:18 PM
bonesbrakr's Avatar
bonesbrakr
MAkes me wonder what goes bad that cant be replaced.
Old Aug 20, 2020 | 06:35 PM
raulg4id@gmail.com
Cruising
Thank you very much for your input. I do have an M part, I will keep checking E Bay then. All the best!
Old Aug 20, 2020 | 10:47 PM
Speedy007's Avatar
Speedy007
Continued fun in exchange for a few bucks . Priceless!
Anyways what makes u think the ecbm is done ?
Old Aug 21, 2020 | 01:48 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Brother, tell me how do you determine if your car has the "V or M"? TIA!
Old Aug 21, 2020 | 03:50 AM
Nyt_Muves's Avatar
Nyt_Muves
The Corvette recycling place where I picked up my engine a couple weeks ago had a stack of these. I mentioned that they are in high demand, but he didn’t seem to sure about what I was telling him.
Old Aug 21, 2020 | 07:46 AM
Harold97's Avatar
Harold97
Check this site I believe they are a forum vendor they list on here, they have the M models for 879 shipped.
www.aescorvetteparts.com
Old Aug 21, 2020 | 10:26 AM
knewblewkorvette
It's printed out on the module.
Old Aug 21, 2020 | 11:14 AM
raulg4id@gmail.com
Cruising
the fact that 2 mechanics in 2 states have told me so and the fact that the ABS and Traction warnings stay on when I drive the car
Old Aug 21, 2020 | 12:01 PM
raulg4id@gmail.com
Cruising
Thank you and checked it out. Unfortunately the serial numbers don't match mine. But will keep checking. My model number is 09360921 for an M unit.
Old Aug 21, 2020 | 01:10 PM
monarch's Avatar
monarch
The module failure is common, my 2001 had it when I got the car and I pulled the module knowing it was a repairable error code (C1214). For reference, I got a price of 2000 dollars from a dealer to fix this issue. I sent it to a repair vendor and had it fixed for 200 bucks.
The first step to do your own diagnosis is to go into the DIC through your dash buttons and get the error codes:
If your code from the ABS section of the DIC is a 1214 or 1218, you might have luck with an EBCM repair. Most places do not do the 97-2000 (apparently the components were internally potted in epoxy compound making the job difficult). You can remove the module yourself, its annoying but not complicated.
https://www.ebay.com/i/222092730569?...iABEgLJnfD_BwE
If the unit is truly lost, ebay is likely your best option. This used one is 1200 bucks, not great but less than I've seen.
https://www.ebay.com/itm/1998-2000-CORVETTE-C5-EBCM-TCS-ABS-BRAKE-PUMP-MODULE-ASSEMBLY-09353621-CODE-M/124278029806?_trkparms=ispr%3D1&hash=ite m1cef8c3dee:g:o2wAAOSweqpeoGBL&amdata=en c%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%25 2Fn%252BzU5L90Z278x5ickkp2NA0WuhQytmt4db Stg00NkjeEDYq7qLHJdD8aiG%252FObWoxrrizpu v5NU7wDE2haX6GwTqYSLNH37Noj8nVnOt2InO3y7 %252F%252BZqzIVEs15fRj0yR8dqTcx%252BlYTA Yg%252BexxYv3ZsCdT60%252FE%252BfccHXPh6S 0KyAniS36UPrOSPRIaTI272i5Jg8RGtbYPO6uCWa nN0PUbApuq6%252FytY6K8yPPglwbsuNHWTx%252 F9u5pelsKUcBxFyNGrfGgRzKXI0czJZ%252FdqdN uUGk4vYfssv%252BxakOeAl8Tu22e%252BXVUzvd fhVBVVkvDHz1g93dLu6fB6vF45W9vzhoWoMgHm9j KKG0XhLa9JXo6ABaaqsmosn7lMzadSkslSRhwGnK eMaTxh21RL5gORBwXfik01HKAkAla%252FUFF4Ty KCKIWXDa2Z%252F9nRPgEMLRQLtfLY2%252BSW2I GRwVj7MzaV434eaCHxJEoTiPlrpT5Oz%252F5eGS hpkHgAhYZQEOFaJQHGZymVkZK3LXk2D7an4kakMs 5PTdmg1cA4JNc0EtsC4jEm0WeIvfJDZmmd8O%252 FgWRnP%252BgCJwc%252B6o%252FM98SJ5Rg%252 BtVKP%252F94ogjbFESi3BHNy6LCPlzI4RbVIkVC pHYtpybQHkhRHsOmFC%252BsInV1Efrr7r6tH0Tp Rk69j%252BsmSx3US8Wr7lwuTOg6gRaAzxIy3E1h d40SzUf6fU8JTcOKMli15T71Zqy2cBmQMek0ygAF HsH%252BvU%252BQYoCQoZbXzb8EiIT4
yHGTt2kAI2cmLujQkG8NNroBKMTpwA%252Fch2fE O8iBsJWU3A%253D%253D%7Ccksum%3A124278029 806afd3d01816c54270b23df86bccf02317%7Cam pid%3APL_CLK%7Cclp%3A2334524
I'm not sure what the different between M and V codes are, but heres a V version for 425 bucks:
https://www.ebay.com/itm/97-2000-Cor...IAAOSweQVfCG8r
Old Aug 21, 2020 | 01:28 PM
Speedy007's Avatar
Speedy007
Thats the fact your car cars starts and drives and that’s a wire interference.....hence open tapping a metal object ....not the module car wouldn’t run with a spent module
Old Aug 21, 2020 | 01:29 PM
Speedy007's Avatar
Speedy007
Your two mechanics I bet are wrong ....problem can be resolved with no module replacement.
Old Aug 21, 2020 | 01:31 PM
Speedy007's Avatar
Speedy007
U could have a bad sensor for all u know ...I am surprised someone has t jumped in yet and said the same ...what codes do you have ?
Old Aug 21, 2020 | 04:57 PM
raulg4id@gmail.com
Cruising
I have an M unit, so a V is not compatible. Also my error code is C1243. I have not seen anything for my serial # except the $2700 one. I also understand that after 2000, it is more possible to fix that unit. My car was put through the diagnostics.
To Need Your Opinions Please
Old Aug 21, 2020 | 05:01 PM
raulg4id@gmail.com
Cruising
Well then you know more than the 2 highest rated mechanics, one a GM certified one, from Moorpark CA and the other one in Meridian Idaho.
Old Aug 21, 2020 | 06:32 PM
Speedy007's Avatar
Speedy007
Your code relates to a abs pump not functioning not a ecbm module ...given the abs and traction control are linked if your abs pump/ module fails then ya your abs and traction control light will be on again it’s not a module but still a expensive fix if you want new parts otherwise check the wrecking yard for stuff you need
Old Aug 21, 2020 | 09:36 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
V model = with Active Handling
M model = without Active Handling
(And as knewblewcorvette pointed out, the code will show on the module itself).
