pcm pinout question
Old Aug 22, 2020 | 01:25 PM
ecook48's Avatar
ecook48
Default pcm pinout question
So i am in the process of re pinning pcms and was wondering if all ground is ground? going between the the 2 pinout charts the grounds are labeled differently, but isnt ground a ground regardless?
Old Aug 22, 2020 | 06:27 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Some grounds are called “low reference” which are PCM grounds...you also have your body grounds !!
Old Aug 23, 2020 | 08:49 AM
ecook48's Avatar
ecook48
on the 98 pinout sheet there was pcm ground jumper, pcm ground and ground, on the 01 pinout i beleive they where just titled pcm ground and ground.
To pcm pinout question
