No power at all
Old Aug 23, 2020 | 01:05 PM
ensteele's Avatar
ensteele
St. Jude Donor '13-'14-'15-'16
Default No power at all
My son moved my corvette from where I normally keep it to another building a couple of months ago, but didn't put the battery tender back on. I was going to drive it, but the battery was dead, or so I thought. It was an older battery, so I decided to replace it. When I hooked up the new battery which was charged, there was no power at all. I have checked everything again, but still no power. Any ideas on what the trouble might be? This is a 2003 C5 convertible which is stock with 32,000 miles stored in the garage and not outside..
Thanks in advance.
Old Aug 23, 2020 | 02:33 PM
mmartinez's Avatar
mmartinez
Are you proficient with multimeter, if so make sure the battery is at 12.5volts which means the battery is fully charged. Recheck the battery cables make sure they are clean and tight, you should not be able to move them if they are. Helped somebody recently with this same problem, found out that somebody had left the power cable that feeds the interior fuse box disconnected, they had been troubleshooting an excessive current drain problem. That cable is located underneath the engine fuse box cover and is bolted on to a threaded stud.
Old Aug 24, 2020 | 01:03 PM
ensteele's Avatar
ensteele
Are there any other ideas? Thanks
Old Aug 24, 2020 | 06:46 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What do you mean “no power at all”...where ???...we need more info !!!
Old Aug 25, 2020 | 02:14 PM
ensteele's Avatar
ensteele
After replacing the battery, I don't have power at the key, lights, or anything else. I checked the battery connection cables and fuses, but no power.
Old Aug 25, 2020 | 05:31 PM
Grandpa1's Avatar
Grandpa1
Almost has to be a cable problem.
Old Aug 26, 2020 | 12:01 AM
ensteele's Avatar
ensteele
Is there a fusible link that could be blown?
Old Aug 26, 2020 | 02:39 PM
mmartinez's Avatar
mmartinez
There is a fusible link in the wire that connects the alternator to the starter solenoid, but it would not cause the no power condition you have. Have you checked the negative power cable connection to the engine block, very baffling to me why your car has no power, battery power is sent to the starter, the engine fuse box, and the interior fuse box. Have you also checked all your fuses, especially the one that sends power to the ignition switch.
To No power at all
