Active Handling lights going on and off
Old Aug 25, 2020 | 10:03 AM
00redVert's Avatar
00redVert
Default Active Handling lights going on and off
What's up with this? I was able to get my bcm replaced with a used but re-flashed unit. I installed it, went through the 30 minute relearn, and to my relief the car started and ran. I took it for a short drive and it seemed ok. BUT, I now have an airbag light that won't go off and more concerning, the active handling goes on and off by itself, repeatedly. Feels a little like a loose wire or something that makes intermittent connection, but it has never done that before. I think I can get the airbag light to cooperate by getting the programming corrected (another dealer visit), but the active handling is bizarre. Any ideas guys? Thanks.
DIC code: SDM B1001 H C
2000 Convertible
Last edited by 00redVert; Aug 25, 2020 at 11:45 AM. Reason: additional information
Old Aug 25, 2020 | 11:27 AM
oharal's Avatar
oharal
Check the DIC for codes and post up what you find.
Old Aug 25, 2020 | 11:44 AM
00redVert's Avatar
00redVert
2000 convertible. Only one DIC code: SDM B1001 H C
Old Aug 25, 2020 | 11:51 AM
oharal's Avatar
oharal
Well that at least explains your airbag light. See here: https://www.corvetteforum.com/forums...post1574934035
As for the AH light, are you getting a failure off and on or a notification that the system is activating at random? What else changed on the car or was touched recently?
Old Aug 25, 2020 | 12:13 PM
00redVert's Avatar
00redVert
When I start the car I get the message that AH is off, so I push the button to turn it on. But then it changes back and forth, on and off, on its own. Dash light goes on and off. ? I did check to see if I could get into Competitive driving mode, and it did. I didn't leave it there while driving to see if that would go on and off too. Maybe I should have. Aside from the replaced BCM (failed after a/c dripped water on it - have that drain fixed now), I have a new turn signal switch, new flasher unit, some new LED lights with an anti-flash circuit added. But that all worked fine before the bcm shorted out. This is a whole new symptom since I replaced the BCM.
Old Aug 25, 2020 | 11:15 PM
1KLRTOY's Avatar
1KLRTOY
The burned contacts in the ignition switch can cause a lot of problems, might want to check if its the original switch.
Old Aug 26, 2020 | 09:12 AM
c4gone's Avatar
c4gone
For me the abs and traction control notification started popping up right after I did plugs and wires. Sometimes it comes on and sometimes it doesn't . Weird..,..sorry, didn't mean to hijack the thread
To Active Handling lights going on and off
