Leaf springs...
Old Aug 29, 2020 | 01:46 PM
clutch1's Avatar
clutch1
Default Leaf springs...
Got a set of used leaf springs...numbers are..22200990 22200996....what did they come off of?....i have c5 bace.......looking for c6 zo6 springs for my car.....the springs dont match up.....john..............
Old Aug 29, 2020 | 03:13 PM
scorpiofox69's Avatar
scorpiofox69
Those are from a C6 Z06 car (990 front, 996 rear). Front should bolt up just fine. The rear will not interchange.
Old Aug 29, 2020 | 03:45 PM
clutch1's Avatar
clutch1
o my gosh.....Tried rear first...your right they dont match....Do I put my old one back on?
Old Aug 29, 2020 | 04:05 PM
scorpiofox69
This is what I did for the set-up on my 04 stick vert. Street and no tracking in the selection of parts. Keep in mind that suspension geometry/ratios must be kept relatively proportionate to spec in order to prevent understeer/oversteer concerns.
I assembled the following for my car and it handles very well for a Vert:
C6 Z51 front spring
C5 Z51 rear spring
C5 Z06 front sway bar
C6 Z51 rear sway bar
Poly bushings
Metal end links (if not already equipped)
I sourced the springs, and sways used. The end links were new.
Old Aug 29, 2020 | 04:08 PM
scorpiofox69
Source a C5 Z06 rear spring and call it good.
How quick do you need the car back up and running?
Old Aug 31, 2020 | 09:43 AM
clutch1's Avatar
clutch1
Have time?...........
Old Aug 31, 2020 | 11:55 AM
jdmvette's Avatar
jdmvette
Night Owl for life
There's a rear Z06 spring here
https://www.ebay.com/itm/97-04-Corve...sAAOSwk1VfF4rZ
Old Aug 31, 2020 | 12:07 PM
clutch1's Avatar
clutch1
I have a two from a C6 Z06..................and sway bars...so far the sway bar works, but the spring wont...And its from a zo6...so he said?........Thanks......
To Leaf springs...
