coolant leak
Tough to repair plastic in this area because of the pressure and heat pushing outward against the repair. I have never read of an effective repair, and was kind of surprised plastic welding didn't work in the one report I read about that approach.
Some guys go nuts and buy a really nice full metal radiator, at about four times the cost of the lighter plastic, when they have a stock motor, which is designed for the operating temps of a stock cooling system. Just trying to wave you off of that commonly offered advice, unless you plan on design changes.
They used to make a dedicated radiator for each variant , but now it is universal, and has the hose holes for every model, as I understand it. I had a guy do it, so am a little vague on the details, and can't answer your question about the AC lines, but was not charged with any AC refrigerant labor for my convertible.
While it is out, you might check to see if the radiator supports are smashed up from parking events. At least I think that is what is damaged under my front end, I didn't know the car well enough when I got my radiator, to consider replacing them at the time, and probably should make sure the commonly damaged under parts I am talking about are in fact, part of the radiator supports.
The new radiator lowered my running temps about five degrees, still comfortably within stock range, I guess it had a bit of scale inside, being on the job since "03.
All the best with your repair. As the above poster suggested, with less words and hub bub, , it's new radiator time. I read the cooling system is the most common cause of engine failure.
