security override for steering column lock?
Old Aug 30, 2020 | 08:50 PM
George Wright's Avatar
George Wright
Default security override for steering column lock?
My '98 steering column is locked. ( the pull key/wait 10 seconds does not unlock it),
I jerked on the wheel and something "popped"---can turn steering wheel now, but when I begin to drive the car, it cuts out. Suppose it is a security feature.
So, is there a way to override the security cut off? I'd like to drive it home versus trailer, and repair it at home.
Thanks in advance,
George
210 748 4693
Old Aug 30, 2020 | 09:24 PM
mmartinez's Avatar
mmartinez
No easy way to override the 2mph fuel cut off, you would have to install an LMC5 bypass, or have someone with tuning software change the 2mph fuel cut off to 200mph. You might try disconnecting the battery for say 10 minutes and see if that clears it.
Old Aug 31, 2020 | 08:25 AM
oharal's Avatar
oharal
Call Richard at Compliance Parts and sleep easy after the LMC5 arrives in a couple days.
http://www.complianceparts.com/?_sm_...7kDZf4t7QRPTLD
Old Aug 31, 2020 | 09:03 AM
Gordy M's Avatar
Gordy M
The security shut off was programmed in by the Dealer as on the (sic) GM fixes. You can tune it out with one of the several software tuners (EFI Live, HP, etc). The will change the shut off speed to 256 mph. The Compliance Parts product will keep the steering wheel from locking again.
Old Aug 31, 2020 | 07:35 PM
3sACROWD's Avatar
3sACROWD
Get your battery load tested. It may be weak. Low voltage on these cars makes them very unhappy.
To security override for steering column lock?
