Checking Ride Control
Old Sep 1, 2020 | 03:39 PM
fatboy999's Avatar
fatboy999
Default Checking Ride Control
I have a 2001 Coupe and am wondering Is there anyway to see if the ride control is working on a C5? I have tried all 3 settings and I can't tell any difference in the Ride. Is there any computer diagnostics available to check the system out?
Old Sep 1, 2020 | 05:15 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I would read the DIC and seem there are any codes set.
Old Sep 1, 2020 | 05:34 PM
jcgunn's Avatar
jcgunn
Are you the original owner? If not, the PO could have deleted the system.
Old Sep 1, 2020 | 05:49 PM
johnson-rod's Avatar
johnson-rod
What kind of tires are you running? Goodyear runflats are hard and make all settings seem the same. Hard. Michelin AS/ZPs are run-flats but softer and you can feel the differences in the settings better. Non-runflats are even better yet. Until you have a flat.
Remember you are just changing the shock settings not the springs.
TOUR can be kind of wallowy above 40mph but is great for bumpy in-town roads.
SPORT is firm - as a Corvette should be. I leave it in this setting except when the bumps get to me.
PERF is HARD as a race car. Better be on a smooth surface like the parkway or turnpike and it better be summer. It's like it has no suspension at all.
Another way to reset the system is to disconnect the battery for a few minutes. Everything electrical in the car resets to initial factory settings including the suspension. (be sure you have the radio's anti-theft code) After everything quiets down take it out for a ride on different surfaces at different speeds.
Old Sep 1, 2020 | 05:57 PM
fatboy999's Avatar
fatboy999
Hi JC, no, I'm the 3rd owner, so i don't know the history of the car.
Old Sep 1, 2020 | 09:09 PM
jcgunn's Avatar
jcgunn
Okay, so do a visual inspection of the shocks. If they have wires coming out of them then they are probably OEM F55s which may have failed (check for oil leaks). If they say "Bilstein" or some other brand without wires, then the PO has deleted the system with a Tech-2.
Old Sep 2, 2020 | 02:36 PM
jackthelad's Avatar
jackthelad
F45 not F55 for that year, and BTW the F45 system can be "fooled" with some resistors if the shocks are replaced - no Tech II needed. I have F45 on my '98, and I can still tell a difference. It's less than it used to be, but "perf" is still noticeably harder. There's a "ripply" piece of road near me where every vehicle tends to bounce for a few cycles as will the C5 unless its in perf - then it's just one quick movement, with no "aftershocks".
Personally, I have always like "tour" on the freeway as it really is comfortable for long runs.
Old Sep 2, 2020 | 05:19 PM
danmclaren's Avatar
danmclaren
When people say they can't feel any difference between settings I always wonder if the switch itself is bad. If everything is working there should be a noticeable difference between modes. The switch is $109 dollars or something like that. Do you know anyone with the same setup that you could swap switches with?
Dan
Old Sep 2, 2020 | 08:29 PM
jackthelad's Avatar
jackthelad
Dan
Depends on the mileage. If the F45/F55's are "done", which they may well be on a high mileage car, there won't be a lot of difference. It's a very simple switch by the way - a multimeter can tell you if it is working or not.
Old Sep 3, 2020 | 12:01 AM
Michael Clemans's Avatar
Michael Clemans
I'm 3rd owner and one of the :PO's lowered all 4 corners to the bottom of the stock bolts but I feel very little difference in the 3 settings. Wondering if that happened when it was lowered. I'm betting it is.
Old Sep 3, 2020 | 10:33 AM
jackthelad's Avatar
jackthelad
Originally Posted by Michael Clemans
I'm 3rd owner and one of the PO's lowered all 4 corners to the bottom of the stock bolts but I feel very little difference in the 3 settings. Wondering if that happened when it was lowered. I'm betting it is.
Mine is lowered all the way on stock bolts. Has been for about 10 years now - no effect at all on how the shocks "feel".
Old Sep 3, 2020 | 09:15 PM
Moved to C5 Tech.
To Checking Ride Control
