fuel pump
Old Sep 2, 2020 | 09:41 AM
Nicole Wilson's Avatar
Nicole Wilson
3rd Gear
Default fuel pump
wanting to know what all is required to replace the fuel pumps in a 2004 corvette
Old Sep 2, 2020 | 10:00 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
The fuel pump is inside the fuel tank. It is a major job that requires taking apart the back end of the car. Here's part 1 of a video it should link you to the other 3 parts.
Old Sep 2, 2020 | 10:01 AM
MWWarlord's Avatar
MWWarlord
Also, welcome to the forum!
Old Sep 2, 2020 | 12:41 PM
Moved to C5 Tech.
Old Sep 2, 2020 | 05:03 PM
rrwirsi's Avatar
rrwirsi
Are you sure it is a fuel pump problem? Why I asked is when the Murano just stopped and would not run, 2 mechanics said it was the fuel pump located in the tank and wanted mega bucks to replace it. After going on line, I found others had the same issue but it turned out to be the cam shaft sensor. So I replaced that and it was the problem.
Old Sep 2, 2020 | 05:08 PM
Nicole Wilson
3rd Gear
The chevy dealership is saying left fuel pump and both fuel level sensors
Old Sep 2, 2020 | 05:09 PM
Nicole Wilson
3rd Gear
Looked it up on all data and weather or not it has a return line system changes the labor about 9 hours
Old Sep 7, 2020 | 10:20 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
If you have a 04 there is no return line. You have the newer type fuel system where the tanks have to be removed to get to the fuel pump. As you noted there is alot more labor involved to remove fuel tanks.
Old Sep 7, 2020 | 09:00 PM
CinciZ06's Avatar
CinciZ06
I did both on mine on my ‘04 while doing my clutch and the English language does not contain enough vulgarity to even come close to compensating for what a pain in the *** it is.
To fuel pump
