need help oil pressure reading high
Old Dec 1, 2002 | 07:17 PM
hot4u's Avatar
hot4u
Default need help oil pressure reading high
for some reason my oil pressure guage is reading 70 psi when i start the car and, 129 psi while driving (plenty of oil )car runs fine just the high reading. idles at 70 psi just started this morning with the high reading
Old Dec 1, 2002 | 08:38 PM
Duck916's Avatar
Duck916
Default Re: need help oil pressure reading high (hot4u)
Most likely it's a bad sender. The oil pump isn't generally capable of generating pressure that high. This has been a fairly common problem.
Old Dec 1, 2002 | 08:42 PM
hot4u's Avatar
hot4u
Default Re: need help oil pressure reading high (Duck916)
thanks I thought that might be the problem off to the dealer tomorrow
Old Dec 9, 2002 | 11:35 PM
cpa_ndnile's Avatar
cpa_ndnile
Just got car back with same problem. Analog and digital both pegged. Replaced oil pressure sensor and everything is fine.
To need help oil pressure reading high
