Crank pulley squeel
Long story short, ive replaced all the accessories and deleted ac on the front of the engine and it would still squeel once it got hot. I pulled the serp belt and it still made the squeel. My crank pulley looks almost new, so i wanted to check for other opinions before i go through the process of lowering my subframe and pulling the rack to replace the pulley. I just dialed in my alignment and would really prefer to not mess it up to replace a pulley that might not even be the issue!
If you have to replace the HB, you dont have to drop the cradle to pull the rack, hell, you dont have to take the rack all the way out to get the pulley out - I didnt. I left it sticking out of the passenger side resting on a stool. Definitely pull the radiator to give yourself more room to work. It took me a day to do it and would have been done faster if it was just a HB / seal replacement. I did the HB, oil pump, water pump, timing components, and of course, the seal that got me in there to begin with. A bonus, it didnt mess with my alignment at all.
PS-Ive already bought a new gatorbelt and katech tension, new alternator ect.
