Cooling problem
Old Oct 23, 2020 | 10:34 AM
  #61
oharal's Avatar
oharal
Originally Posted by oharal
Before buying more parts I suggest measuring the motor winding resistance and compare the two fans. If the bad fan has high resistance or is open circuit compared to the other that is what you will want to know
Originally Posted by Deliso1
Replaced the fans and no change. I’m at a loss and need to find a shop in Chicago area that knows these cars 😓
Did you confirm the fans were bad before replacing them? You should not buy parts until you confirm the issue.
