MN6 Gear Ratios
Old Dec 1, 2002 | 08:46 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Default MN6 Gear Ratios
Where can I find the gear rations for the MN6 - want to calculate speeds through each gear for various final drive ratios. (Unless of course someone has already done this for stock rear tire size, in which case you can just post the results ;) )
:cheers:
[Modified by 70L46, 8:47 PM 12/1/2002]
Old Dec 1, 2002 | 09:22 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Default Re: MN6 Gear Ratios (70L46)
Never mind, found them in this thread:
http://forums.corvetteforum.com/zerothread?id=414732
