Hard to start when cold
Old Sep 14, 2020 | 10:19 AM
jjc508520's Avatar
jjc508520
Default Hard to start when cold
It used to bark to life at the twist of the key - but now it spins longer before catching. Any ideas?
Old Sep 14, 2020 | 01:58 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When only cold I may lean towards an ECT issue...maybe fuel pressure...hard to say without some testing...you can prime the fuel system when cold and see if that resolves it...can even be a cam sensor failing.
Old Sep 15, 2020 | 07:33 PM
jjc508520's Avatar
jjc508520
What about throwing injectors and coil packs at it?
Old Sep 15, 2020 | 07:41 PM
C5 Diag's Avatar
C5 Diag
If you had injector or coil pack issues you’d be throwing some misfire DTC’s !!...coil packs are bulletproof on these cars anyway...when you throw parts at it you’re just throwing money at it !!
Old Sep 16, 2020 | 08:27 PM
fastbroshi's Avatar
fastbroshi
How old is your battery? It's very possible it may not be up to snuff if it's cranking slow. Or possibly your starter is tired or the wiring to it is suspect.
Old Sep 17, 2020 | 09:41 AM
Fast one's Avatar
Fast one
How old are the spark plugs?
Old Sep 17, 2020 | 04:11 PM
oharal's Avatar
oharal
With the level of detail given by the OP, any suggestion is pure guesswork. We need more info, like how long is it cranking, is it sputtering and then firing or nothing seems to happen then its just suddenly running, how does it idle once its running....give us something to go on. If a picture speaks a thousand words, a video must speak a million.
Old Sep 23, 2020 | 08:25 AM
jjc508520's Avatar
jjc508520
Here's a link to a video. Its not awful - but like the rest of you any changes - no matter how minor - tend to get your attention.....
https://1drv.ms/v/s!AkYiM3p-XVDUpl1P...Xbf9_?e=Dw0CNd
Old Sep 29, 2020 | 12:19 PM
jjc508520's Avatar
jjc508520
Well here's a twist - after my recent track day it seems to be back to its old self There's a lesson in there somewhere....
Old Oct 3, 2020 | 01:38 PM
Vette02z51's Avatar
Vette02z51
4th Gear
I have this EXACT same issue, symptoms and start. I’ll try to post a video.
My issue also went away for a while but came back. I’m trying to figure out where the fuel check valve is. I believe there is one in the pump and another one in-line but I’m still researching.
Old Oct 3, 2020 | 01:40 PM
Vette02z51's Avatar
Vette02z51
4th Gear
Here is my video. I’m told it most likely is caused by a faulty fuel check valve that is sticking causing the fuel pressure to bleed off overnight.
File Type: mov
Old Oct 3, 2020 | 02:28 PM
AntonioZ06's Avatar
AntonioZ06
Mine seems to be the same exact way. If I let go of the key too early, give it a sec, and try a 2nd time, it starts instantly without the hesitation like in your video. I'm guessing the above poster may be on to something with the fuel pressure bleeding off. But not sure because the pump should prime the system prior to startup.
Old Oct 3, 2020 | 03:19 PM
Vette02z51's Avatar
Vette02z51
4th Gear
what I’ve found is that the pressure bleeds off too much to where the 2 second prime isn’t enough for a smooth start. However, if I prime the pump 4-5 times, it starts perfectly. I’m just trying to figure out now where and how it’s bleeding off. Gm 10448899 check valve seems to be the culprit for many. Unfortunately it’s discontinued. I haven’t seen anyone with a problem with the check valve in the fuel pump. But there’s also less common problem, ie bad injector.
Old Oct 3, 2020 | 05:57 PM
Vette02z51's Avatar
Vette02z51
4th Gear
Does anyone on the forum know where the fuel check valves are?
To Hard to start when cold
