Before I take my car to a dreaded Chevrolet dealer, thought I would run the following past forum members for input:
1. Key fob 1 and 2 both have new batteries
2. Both fobs programmed and compatible with DIC
3. Both fobs will unlock both doors.
4. Both fobs will lock the passenger door but not the driver door.
5. I can accuate the fobs and see the driver door latch acutate and attempt to lock, however, will not fully lock.
6. Any suggestions?
Ed Ledbetter :confused:
Re: Keyless Entry System 2001 C-5 Coupe (EdLedbetter)
6. Any suggestions?
Can you lock the drivers door ok from the door button?
EL, in my 2000 coupe, I have a similar problem except that my drivers door wouldn't open! This only started happening a few days ago. Even using the electronic unlock from the driver's door won't work. After about 10-15 tries it will finally work. I believe kewlbrz is on the money suggesting that it may be a mechanical failure since after I manually moved the lock/unlock lever on the door several times it has worked for the past two days. I hope this fixes it permanently. If not something may need lubing behind the door.
