Overheating
Old Sep 25, 2020 | 04:29 PM
K218's Avatar
K218
Cruising
Default Overheating
Hey guys, I have a 2000 Corvette and it over heated the other day to full 260+, I just changed the thermostat and now when idling the temp will go to 235 and the fans will turn on the temp will continue to rise to 240-245 then due to the fans drop back down to 220-225. Once the fans turn off again it will rise back up and fall back down, it continues this cycle. Is this normal or is hitting 245 way too high. Fans turn on at 235 consistently.
Old Sep 26, 2020 | 11:17 AM
silver50's Avatar
silver50
I think your fans should turn on around 200/210. Then go on at high speed at your 235c.
Old Sep 26, 2020 | 11:20 AM
helga203's Avatar
helga203
I'm i freaking out or is there 2 threads going on here.
Old Sep 26, 2020 | 11:31 AM
tentuna's Avatar
tentuna
Did you burp the system, if you changed the thermostats, the system would have been emptied. the procedure is pretty easy, start the car, let the stat open shut it down slowly release pressure by opening the cap, the system should release trapped air refill and repeat if necessary.
Old Sep 26, 2020 | 01:05 PM
My Vette Life's Avatar
My Vette Life
we're certified internet mechanics, please subscribe for only $20 a month for a certified mechanic to reply.
Sincerely, the manager.
Old Sep 26, 2020 | 01:58 PM
K218's Avatar
K218
Cruising
Yes I accidentally double posted due to this being my first time on this site
Old Sep 26, 2020 | 02:00 PM
K218's Avatar
K218
Cruising
How long do i let the car run for?
Old Sep 26, 2020 | 03:15 PM
Ed Ramberger's Avatar
Ed Ramberger
Two identical posts simultaneously running
To Overheating
