p0131, p0151
Old Sep 26, 2020 | 06:30 PM
Venom602's Avatar
Venom602
Default p0131, p0151
so i got the dreaded codes i got new 02sensors installed checked fuses cleaned maf sensor need to check for exhaust leaks now and clean ground iam stock(2001). Not sure how to fix it and get rid of the codes im in AZ if anyone knows a good mechanic that can fix it completely please let me know or stuff i can try, these are my last 2 codes i dont have nothing to read volts
Old Sep 26, 2020 | 09:02 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
To diagnose this issue successfully you really need to have a scan tool to look at your O2 sensors and also your fuel trims...if the PCM sees the O2 millivoltage less than 200 mv for about 30 seconds the DTC will set...you’d be better off taking it to a mechanic especially if you don’t have a scan tool or a DVOM to look at the wiring !!
Old Sep 26, 2020 | 09:07 PM
Venom602's Avatar
Venom602
would a general mechanic be able to do this? the car is running fine getting like 21-24mpg, yea i dont have any of that
Old Sep 26, 2020 | 09:09 PM
C5 Diag's Avatar
C5 Diag
If you can find a diagnostic shop you you’d be better off...a “general” mechanic would just be changing parts and that can get expensive !!
Old Sep 26, 2020 | 09:34 PM
Venom602's Avatar
Venom602
so have someone use the diag tool and verify whats wrong then get that fixed? what if they give me an i dont know answer.....
Old Sep 27, 2020 | 06:06 AM
C5 Diag's Avatar
C5 Diag
The scan tool isn’t going to tell you what needs to be replaced but the person looking at the data it’s providing will be able to interpret that data...the low O2 sensor low voltage code isn’t a really hard one to diagnose but finding a good diagnostic tech is...contact your local Corvette Club in your area and see who is recommended...that is about the best I can do for you...did you do any mods or have any repairs done to the car recently ???... ie...headers etc ??....that would help !!...did you use OEM O2 sensors ??...not a good idea to use aftermarket ones on these cars.
Old Sep 27, 2020 | 07:40 PM
Venom602's Avatar
Venom602
sadly they were not oem based sensors and a cat converter thats about it. haha dont know any corvette clubs sadly either only fellow vette lovers on the street
Old Sep 27, 2020 | 07:41 PM
Venom602's Avatar
Venom602
i just want this thing fixed finally
To p0131, p0151
