Spare key programming
Old Oct 2, 2020 | 10:29 PM
VegasVette702's Avatar
VegasVette702
Default Spare key programming
I’m running into an issue, so I can program the key (10:30 on/offx3) blah blah blah... anyway... it works after all that... starts the car. After I program the new key... the original key no longer starts the car. Help? I’ve successfully drained the batt trying to reprogram the original key lol charging that now. Do these only allow one programmed key to be paired?
Old Oct 4, 2020 | 07:37 AM
VegasVette702
Default Help?
Anyone?
Old Oct 4, 2020 | 11:57 AM
Harold97's Avatar
Harold97
Do you mean your FOB? Are you using the FOB learn on the DIC?
Old Oct 4, 2020 | 12:15 PM
Autoeng's Avatar
Autoeng
Two keys can be programmed.
Old Oct 4, 2020 | 02:21 PM
VegasVette702
Default Ty
I’m doing something wrong then... cause when I program the second one... it wipes the first one... then if I put the first one back in the ignition... it wipes the second one as well.... then I have to reprogram the first one again...
Old Oct 4, 2020 | 02:22 PM
VegasVette702
Default No
no FOB’s were easy... talking about ignition keys
Old Oct 4, 2020 | 02:47 PM
jcgunn's Avatar
jcgunn
Your two keys must have different VATS resistors. Use an Ohm meter to check the value on each key.
Old Oct 5, 2020 | 07:51 AM
runner140*'s Avatar
runner140*
Correct....there are 15 different VATS key resistors .......purchase the correct key.
To Spare key programming
