Transmission/Differential Mounts
Old Oct 6, 2020 | 10:09 PM
fffttt1's Avatar
fffttt1
Default Transmission/Differential Mounts
I installed a Pfadt style differential mount, then removed/sold because I didn't like the added vibrations in the cabin. Then I bought/installed a used Hinson poly differential mount. It's currently in my '02 C5Z. Not as much vibration transmitted to cabin. Here's the question: With each mount installed I get a fairly violent vibration forward near the bell housing area during hard acceleration. Felt like the front end of the drive train was hitting the floorboard. This was different from the rear shake that I would get with the stock rubber differential mount. I'm theorizing that the stiffer rear mount causes the rubber engine mounts to shake. Should I install poly engine mounts to enhance the stiffness of the poly differential mount? (Not interested in solid engine mounts.)Shoot me some opinions.
Old Oct 7, 2020 | 08:55 AM
robmiz's Avatar
robmiz
Did you measure the height of the diff mount? If it slightly taller it can push the torque tube closer to the tunnel frame...the shifter mount to tunnel frame is closest contact point... I installed non oem diff mount and the gap went from 1/4” to 1/8”.... on aggressive acceleration it would bang loudly...
Old Oct 7, 2020 | 09:52 AM
fffttt1's Avatar
fffttt1
I'll have to jack her big butt up high and measure the installed mount. Then measure the OEM mount, and compare.
Thanks for the info......
Old Oct 7, 2020 | 12:47 PM
MetalMan2's Avatar
MetalMan2
Recently I did a transmission synchro rebuild, rear main seal+cover and full clutch job, torque tube rebuild, and LSD rebuild. I also put in the Hinson poly diff mount.
Afterwards there was some noticeable vibration that I don't think was present beforehand (though the car was down for 3 months, I could've forgotten).
I too surmised that there could be extra stress on the stock/original(?) motor mounts, so I bought some inexpensive replacements off RockAuto. Haven't installed them yet, though.
If motor mounts don't resolve this for me, I'll get a new stock-style diff mount. The extra performance of the Hinson poly mount isn't totally necessary since the car is mostly a DD. The small amount of added vibration would be totally acceptable if it was a weekend driver or track type car.
To Transmission/Differential Mounts
