Monster clutch twin disk questions.
Old Oct 10, 2020 | 08:05 AM
04zjimc's Avatar
04zjimc
Default Monster clutch twin disk questions.
So i got my car back from the tuner, had a twin disk installed with the light weight flywheel. What is the trick to taking off in first gear without stalling? It came with 2 options a 20lb and 24lb flywheel I should add that I had a cam installed also. Thanks
Old Oct 10, 2020 | 11:15 AM
helga203's Avatar
helga203
Not kidding you have to give more gas and let clutch out slow. Twins are funny. You just have to get use to its much different then the stock. You have a learning curve.. Plus you have the light flywheel.
