C6 LS2 into C5
Old Oct 12, 2020 | 03:36 PM
BURL's Avatar
BURL
Default C6 LS2 into C5
I'm ill be transplanting a C6 LS2 into a C5. Will the C6 pan fit the C5 OK? I think the C6 pan is Oil pan # 12624617.
Old Oct 12, 2020 | 05:33 PM
bonesbrakr's Avatar
bonesbrakr
You would be better off just re using the C5 pan.
Old Oct 12, 2020 | 07:40 PM
BURL's Avatar
BURL
I'm pulling my LS1 out complete. , Building LS2 up from block. Will need to buy a pan
Old Oct 13, 2020 | 09:29 AM
oharal's Avatar
oharal
What are you planning to use the car for?
Old Oct 13, 2020 | 10:59 AM
BURL's Avatar
BURL
Mostly street car. Occasional trip to the drag strip. No roundy round or road course. No real need for batwings. Will use crank scraper and windage tray if appropriate with replacement pan.
Old Oct 13, 2020 | 02:36 PM
RonSSNova's Avatar
RonSSNova
Yes the C6 pan fits. Quite nicely. More room for headers, starter replacement etc.
Old Oct 13, 2020 | 04:08 PM
BURL's Avatar
BURL
Great answer. Helps a lot. I'm sold on the C6 pan specially with the increased room for headers, etc.
Old Oct 13, 2020 | 09:54 PM
RonSSNova's Avatar
RonSSNova
I noticed at the drags, oil pressure dropped a bit at the launch. I’ve only made two passes with the new 6.2.
Ive added a quart, will test again. So you might consider the improved racing baffle crank scraper setup. I can see that adding that to mine would be a nightmare with the engine in the car.
Car ran 10.79 second pass.
Swap over the C5 oil level sender. C6 has a diff connector.
I put a 24x reluctor in mine as well. Just easier than an adapter box. Need the C5 crank trigger too.
Other than that, the C6 pan is a direct fit
Old Oct 16, 2020 | 10:43 AM
FourG63 97GST's Avatar
FourG63 97GST
Fits perfect, I run LS2 with C6 pan, gives more room also
To C6 LS2 into C5
