Idler Pully?
Old Dec 4, 2002 | 12:53 AM
Jackal's Avatar
Jackal
Default Idler Pully?
How hard is it to replace the idler pully?
Old Dec 4, 2002 | 03:04 AM
jmX's Avatar
jmX
Default Re: Idler Pully? (Jackal)
Should just be held on with a 15mm nut that you turn loose. It should be very easy.
Old Dec 4, 2002 | 02:22 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Jackal,
The idler pulley on my 1999 C5 coupe was replaced by my dealer based upon a TSB for a squeaking pulley. The labor allowance was 0.3 hours.
Old Dec 4, 2002 | 02:53 PM
GmasterB's Avatar
GmasterB
Replaced mine yesterday, took about 4 minutes. I also replaced the belt at the same time, it had a crack or two in it, so good thing I did.
Old Dec 10, 2002 | 04:42 PM
Jackal's Avatar
Jackal
Default Re: Idler Pully? (GmasterB)
Do you have to remove the belt to get to the Tensioner?
Old Dec 11, 2002 | 09:39 AM
sbkim's Avatar
sbkim
I have the same question
Old Dec 11, 2002 | 11:14 AM
Jackal's Avatar
Jackal
TTT
Old Dec 11, 2002 | 11:51 AM
TLewis4095's Avatar
TLewis4095
The tensioner is upper-most pulley on the car, passenger side. Mine started to come apart this past weekend at the Snowbird Nationals during qual runs. (ran a 12.39 @ 113 after the belt threw around the 1/8th mile mark) and it threw the belt....got up to 245 degrees by the time we were back up the return road. I had to wedge a washer under the underside of the unit to get the belt to ride straight. Like mentioned above, 2 15 mm bolts and you just need to slide the belt off of it to replace. :cheers:
Old Dec 11, 2002 | 12:38 PM
Jackal's Avatar
Jackal
Default Re: Idler Pully? (TLewis4095)
The Tensioner and the Idler pully are two different things. The Idler pully is to the upper right of the water pump, and is about 2.5 to 3 inches in diamater.
Old Dec 11, 2002 | 02:01 PM
sbkim's Avatar
sbkim
Well, I just pickeed one up over lunch. Let's hope this does the trick. I hope someone can post detailed instructions on removing and installing one... Or is it THAT easy - removing the bolt, undoing the belt, putting on the belt, and tightening the new pulley...
Old Dec 11, 2002 | 03:19 PM
TLewis4095's Avatar
TLewis4095
Default Re: Idler Pully? (sbkim)
Very easy, but Jackal is right, make sure you have the right one.
Old Dec 11, 2002 | 03:41 PM
ProDesign's Avatar
ProDesign
Anyone know torque for tightening idler pulley bolt?
Old Dec 11, 2002 | 04:38 PM
sbkim's Avatar
sbkim
Default Re: Idler Pully? (ProDesign)
37 lb ft.
do you know how to get the belt off the pulley? Any guidance????
Old Dec 11, 2002 | 04:53 PM
ProDesign's Avatar
ProDesign
SBKIM,
You will need a 15mm socket on a long socket wrench/breaker bar (The longer the better). On the passenger side on the front of the motor you will see the drive belt tensioner. Simply rotate the bolt on the drive belt tensioner pulley clockwise to relieve tension on the belt and remove. You can now replace the idler pulley.
Make sure you note belt routing prior to removal.
While your at it, could you please tell me the GM part number printed on the drive belt.
[Modified by ProDesign, 5:05 PM 12/11/2002]
Old Dec 11, 2002 | 10:54 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Clockwise?
Old Dec 12, 2002 | 09:08 PM
sbkim's Avatar
sbkim
Default Re: Idler Pully? (CapeCodCoupe)
There is a difference between an Idler Pulley and Belt Tensioner Pulley. It seems like most people are referring to removing the belt tensioner pulley - quite easy. The Idler pulley is on the driver side- far below the alternator. This looks like a helluva work to get it replaced.
To Idler Pully?
