AC compressor
Old Oct 15, 2020 | 09:41 PM
enb98's Avatar
enb98
Default AC compressor
does anyone have any experience replacing the AC compressor in a 2000 c5? if so please dm me so we can talk
Old Oct 15, 2020 | 10:01 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Or.... since this is an open forum, just ask your question and we can help?
Old Oct 16, 2020 | 07:24 AM
mrwick01's Avatar
mrwick01
A lot of things need to be removed just to remove the compressor. The biggest thing is the freon unless yours has already leaked it out. I had an estimate 3 days ago of $700.00 just for the labor. I have a new compressor and dryer which are the major parts for the job. My compressor is still blowing cold but very noisy at times and I think it locked up once kicking off the drive belt. I think I could replace it myself except for the freon.
Old Oct 16, 2020 | 07:49 AM
Stingroo's Avatar
Stingroo
It's not a fun job. I did it on mine, and if it fails again, I won't do it again.
Old Oct 16, 2020 | 09:30 AM
tentuna's Avatar
tentuna
I did mine this past summer, with the receiver dryer, strainer and condenser luckily the compressor did not destroy itself so did not have to flush the balance of the system (evaporator). Wasn't bad replacement, exhaust manifold and water pump have to come off just a lot of wrenching but not not difficult. After all is replaced evacuate system and 26 oz of R134a and you are done.
Old Oct 16, 2020 | 12:10 PM
Moved to C5 Tech.
Old Oct 16, 2020 | 12:20 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Like stated already, it's not a really hard job but is time consuming. If your compressor hasn't quit and gernaded the insides then you could probably get by without flushing the system. I did mine a little over a year ago and just took my time. Moving the exhaust manifold made it much easier to get to the rear hose bolt. I have the shorty headers on my car so I'm not sure how the stock manifold is to get access to that bolt. Post up your issues and we'll be glad to help you out.
Old Oct 17, 2020 | 03:50 AM
DWAVette's Avatar
DWAVette
Default Manifold?
I am about to tackle this job on a 99 vert because I believe mine is leaking. In the process of confirming the leak.
I have found a few write ups on this job and don’t recall seeing where the manifold is necessary. I see the water pump needs to come off, though. Actually found one on you-t where he got the compressor out without removing the water pump - but I would not even attempt that.
I attached one of the very clear write ups I found and downloaded, but I have not confirmed this process myself. If anyone can validate this for us, it would be helpful.
File Type: pdf
To AC compressor
