Speedometer Calibration
Old Oct 17, 2020 | 10:03 PM
VetteMan2012's Avatar
VetteMan2012
Default Speedometer Calibration
I just switched my tires from 17 and 18 to 18 and 19. I would like to re-calibrate my speedometer. What do I need to do?
Old Oct 18, 2020 | 07:58 AM
feeder82's Avatar
feeder82
Adjust for tire diameter with tuning software, like HP tuners. Some handheld tuners can also.
Old Oct 18, 2020 | 11:41 AM
jamieo's Avatar
jamieo
Depending on the tire size you used,calibration may not be needed.What size rear tires did you go with?
Old Oct 18, 2020 | 08:50 PM
VetteMan2012
I went with 285/35/19 on the rear.
Old Oct 18, 2020 | 09:02 PM
jamieo's Avatar
jamieo
Were you running the 275/40/18 tire before?If so,you won't need any adjustments. https://tiresize.com/calculator/
Old Oct 19, 2020 | 07:36 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I did the same swap and there was no noticable effect. Speedometer is still accurate to <1 mph at 60mph as compared to GPS speed.
Old Oct 19, 2020 | 09:05 PM
VetteMan2012
Thanks for the info.
To Speedometer Calibration
