Hazard Lights Hyper Flash Only with Engine Off
Old Oct 27, 2020 | 07:48 PM
LIGHTNING's Avatar
LIGHTNING
Default Hazard Lights Hyper Flash Only with Engine Off
Installed LED Switchbacks, Halo Taillights, and Hyperflash Harness about 7 years ago.
Everything functioning properly...until now.
When engine is off and I activate hazards, I get hyperflash. Only happens when engine isn't running.
Any ideas?
Old Oct 27, 2020 | 08:42 PM
Ed Ramberger's Avatar
Ed Ramberger
Any ideas?
Is the voltage dropping low when off? What happens if you cycle the hazard switch several times?
Old Oct 27, 2020 | 09:27 PM
LIGHTNING's Avatar
LIGHTNING
Interesting you mention voltage drop. I installed new Optima Red Top about a year ago. My garage has no electric so I can't use my Battery Tender, and I don't always drive my C5 on a regular basis. Past few months I've noticed voltage with key in ignition "on" at 11.7, and with engine running varies 13.6-14.2.
Have new garage now with electric and BT hooked up. It fully charged in about an hour. That's when I activated hazards again to see what would happen. Still got hyperflash. Tried it a few times.
Old Oct 27, 2020 | 09:33 PM
Ed Ramberger
I had hyperflash with the rear halos that had resistors only when voltage dropped to a certain point. I installed a hyperflash harness to remedy it. Remembering back, I think it happened once when the battery was low with the harness. That's why I asked. I asked about the switch to make sure the contacts are exercised. My thought was that you would see it when the voltage drops past a certain threshold.
I don't know if a different LED friendly flasher would fix that. It might if the one in the harness is failing. You would just plug it into the harness - not buy a new harness. Maybe the flasher is on it's way out.
Old Oct 28, 2020 | 12:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Hyperflash is a good thing if you're using hazard lights IMO.
There's some talk of moving the hazard light standard to 5hz in the future.
Old Oct 28, 2020 | 11:03 AM
Ed Ramberger
Would be a good idea I think
Old Oct 28, 2020 | 03:06 PM
LIGHTNING's Avatar
LIGHTNING
Thanks for the info. I'm thinking it may have to do with the voltage drop.
Old Oct 28, 2020 | 03:07 PM
LIGHTNING's Avatar
LIGHTNING
True. And it looks really cool at night especially with the LED's!
Old Oct 28, 2020 | 06:14 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Oct 29, 2020 | 05:06 PM
lionelhutz's Avatar
lionelhutz
The flasher in the hyperflash harness is only used for the signals. The flasher in the hazard switch is still used for the hazards. Did your rear halo lights have load resistors? I've seen pictures of those melted and failed. Removing some of that resistor load or not having load resistors at all would cause the hazard flasher to hyperflash. Lower voltage might cause it to hyperflash too. There is probably nothing you can do about it, because a replacement hazard switch could even be worse.
Old Oct 29, 2020 | 07:28 PM
Ed Ramberger
That makes sense then as it mimics exactly what happened to mine when the voltage was low with a standard flasher module (using signals). When the voltage dropped, even with those load resistors, the things hyper-flashed. As soon as the voltage came up it stopped. I have a set of halo led tails with the integral resistors - none were or are burned. Only flashed faster when voltage dropped low.
I forgot about the flasher for the hazards being separate.
Old Oct 29, 2020 | 07:58 PM
LIGHTNING's Avatar
LIGHTNING
Love it! And I don't even have to buy it now
Old Oct 29, 2020 | 08:11 PM
LIGHTNING's Avatar
LIGHTNING
Yes, rear Halo's came with resistors already installed. I highly doubt they melted since I don't drive it at night often. It may be the lower voltage theory due to the battery. I 'll know for sure when I replace battery.
Old Oct 29, 2020 | 08:15 PM
Ed Ramberger
When I first got the car, before I replaced the battery, I noticed it when it was raining. Lights, wipers, radio, signal on, defroster and a long traffic light and once the voltage hit a certain point every time hyperflash.
To Hazard Lights Hyper Flash Only with Engine Off
