Clutch....question
Old Dec 4, 2002 | 09:23 PM
00c5coupe's Avatar
00c5coupe
Default Clutch....question
Temp outside is drop in the 30s today when i get off work.....the engagement is very lil, close the floor and not too much pressure as it used to. Has anyone have this problem? any wrong with it? The coolling temp at the time was 140 deg. After about ten min drive it feel normal again. Car has 32k miles on it. Thanks for your help.
Old Dec 5, 2002 | 12:01 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Clutch....question (00c5coupe)
i know DOT 3 is not supposed to freeze, but you may want to check your clutch fluid next time it happens. Another explaination could be that you lines got some condensation in it and that froze up.. I am only stabing in the dark, so someone please save me..
