Coilover question..
Old Nov 1, 2020 | 09:30 PM
04zjimc's Avatar
04zjimc
Default Coilover question..
Right now i have stance coilovers and want raise the rear on one side, but the shock will pop out of the cup. Are there coilovers with different length cups? Thanks
Old Nov 1, 2020 | 11:46 PM
opel's Avatar
opel
I have Stance as well.
When you say the shocks pop out of the cup are you saying the cup/shock body is striped out or do you have the cup unthreaded to entire way?
You should not have to unscrew the cup that far you might want to have the coilovers looked at, they could be wore out.
Are they the older Stance? If I remember correctly they changed the length at some time.
Old Nov 2, 2020 | 04:57 AM
04zjimc's Avatar
04zjimc
No not stripped out,I have the newer version. I have a widebody And 19" rear wheels. The shock body is at its max height inside the cup..
Old Nov 3, 2020 | 12:21 AM
opel's Avatar
opel
I don't remember if the earlier or latter coilovers were the longer ones. I'm not recommending this but you could add to the lower or upper mounts.
To Coilover question..
