Help transmission won’t shift
Old Nov 2, 2020 | 09:12 PM
tystang2001's Avatar
tystang2001
Default Help transmission won’t shift
I recently swapped my pcm in my 98 to the newer version. My car starts up and runs fine (finally it wouldn’t start before the swap). However, the car will not shift into third.
anything special o need to do with the tune? I made everything match my old settings in HP tuners. I have triple checked the pins and they are all correct.
Old Nov 2, 2020 | 10:36 PM
Moved to C5 Tech.
Old Nov 3, 2020 | 06:51 AM
Autotragic's Avatar
Autotragic
Newer version? P01 or P59? Upload your tune file.
Old Nov 3, 2020 | 10:15 AM
lionelhutz's Avatar
lionelhutz
Is the 1-2 shift working right?
You started with a stock auto bin, right?
Old Nov 3, 2020 | 01:23 PM
tystang2001
1-2 shift seems to be working fine. I started with the tune that it loaded up when I read the new computer. I then changed it to match the old tune I had with the old computer. How do I tell if it is P01 or P59.
I will load up my tune this evening.
Old Nov 3, 2020 | 01:43 PM
lionelhutz's Avatar
lionelhutz
My understanding is that you can't switch a manual tune into an auto tune by modifying the tables and scalars and flags. You have to segment swap the automatic transmission segment into the manual bin or simply start with an auto bin which is easier since they already exist.
P01 just refers to the 512k PCMs and P59 just refers to the 1M PCMs I believe.
Old Nov 3, 2020 | 04:31 PM
tystang2001
Here is the tune that I am currently using
Old Nov 3, 2020 | 04:43 PM
tystang2001
also the Speedometer is not showing either. I have tried to manually shift the gears (3-2-D) it will only shift between 1st and 2nd gear.
Old Nov 3, 2020 | 05:19 PM
feeder82's Avatar
feeder82
Check the speed sensor on the diff, maybe its not plugged in
Old Nov 3, 2020 | 09:04 PM
Autotragic's Avatar
Autotragic
Try this and see what happens...This is all stock settings from a P01 Auto ECU which is what you have in your car now.
Old Nov 3, 2020 | 09:29 PM
tystang2001
thanks. I will try that tomorrow. Should I do it as a full write?
Old Nov 3, 2020 | 09:40 PM
lionelhutz's Avatar
lionelhutz
The PCM won't upshift the transmission without a speed signal.
Old Nov 3, 2020 | 10:15 PM
Autotragic's Avatar
Autotragic
Try a partial first, I didn't change anything but trans parameters.
A couple things though, has the car been regeared and are you using stock tires sizes?
This does concern me a bit, if the speedo was working this would be easier but it might be two separate issues. The thing is though it is shifting 1-2 but not 2-3 and after looking through the tune file I think I know why but I want confirmation. This might be a I fixed this but now...kind of things. One thing at a time.
Old Nov 3, 2020 | 11:00 PM
lionelhutz's Avatar
lionelhutz
The PCM forces the transmission into 2nd gear when you manually put the shifter into 2nd, even at zero speed.
Will it shift from 1 to 2 as you accelerate if you have the shifter in drive or overdrive?
You have HP Tuners. Monitor the speed signal. Try forcing the gears.
Old Nov 3, 2020 | 11:53 PM
tystang2001
I will monitor speed signal tomorrow. It did seem to shift from 1-2. At least when I first start up and go. It doesn’t seem to want to shift back down though.
Old Nov 4, 2020 | 08:31 PM
tystang2001
Still not shifting. I also replaced the VSS sensor and still no speedometer.
I am having the P0502 code now however.
I tried shifting manually and I can get it to shift between 1-2 only. Sometimes it doesn’t seem to want to shift back down very easily but it will shift between those two gears only.
Old Nov 4, 2020 | 09:14 PM
Autotragic's Avatar
Autotragic
So do you have a multimeter? Try checking for continuity if you're getting any signal across that sensor at all. If there is no continuity at all then you probably just have a broken wire somewhere.
of course finding where the wire is broken at might be a pain in the butt but you know you'll have something to go on.
To Help transmission won’t shift
Old Nov 5, 2020 | 10:08 AM
grinder11's Avatar
grinder11
You are right about the 2nd gear force. I believe GM used to call this function "2nd gear start". I believe it was originally designed for low traction conditions like snowy/icy roads in Northern states......
Old Nov 5, 2020 | 04:18 PM
lionelhutz's Avatar
lionelhutz
Yes, something like that. It really does help starting from a stop in snow (not in a Corvette, but other vehicles).
As for the speedo, re-check the pinning of the speed sensor pins to ensure they go to the right place.
Old Nov 5, 2020 | 05:34 PM
tystang2001
So I have replaced the VSS (same thing).
I have checked the lines from the VSS to the pcm they are good and send signal fine.
I had my ho tuner hooked up and can turn on all of the selenoids and can have the car go into every. Gear using go tuner to manual shift to each gear through the program.
the VSS does not show up on the ho tuner at all and no speed
so my thought is that the pcm is not reading the VSS signal.
it is either pinned wrong or could the pcm be bad as to the VSS only?
i have triple checked the pins. I have a 1998 corvette and the new pcm says it is out of a 2002. I have the VSS pins in the red numbers 20 and 21 (low signal and high signal).
any ideas?
