Rear rattling sound?
Old Nov 8, 2020 | 06:56 PM
95wht6spd's Avatar
95wht6spd
Default Rear rattling sound?
02Z I noticed recently, I have a metallic rattling sound at the back when at idle. I only hear it when idling and I am outside of the car.
Seems like it comes more from the left drivers side, but hard to tell. It is intermittent, and sounds like clunking hollow metal, so my guess is the exhaust. It has the OE Ti mufflers connected to a full Kooks system.
I tried pushing on the exhaust tips with my foot when it was running, but difficult to do, and I didn't notice any change.
I looked around under and didn't see anything the looked odd, but I did notice the passenger side muffler moves more than the other, and when I hit it with my hand, it makes a similar sound.
Should I just put the rear on jack stand with wheels off and feel around? Anyone ever have a baffle in one of the mufflers break loose?
Old Nov 9, 2020 | 08:55 AM
Mikes-Z06's Avatar
Mikes-Z06
Definitely have a look - My Kooks headers connected well overall - but near the rear diff it was making very slight contact over bumps and under hard acceleration. I'm also running the diff brace and a H/C vette. - also running Titanium exhaust with mod.
I think Kooks headers tend to run close to the diff (if I remember correctly it was on the passenger side) - plus my car is H/C too. The rubber clamp/vibration damper around there has a bit too much movement. I had to loosen the exhaust, push and reposition, and tighten down best I could.
Not sure that this is your issue - but might be something to look at, and an easy fix if it is the case.
