U1064 - Loss of communication with DCM
U1096 - Loss of communication with IPC
U1040 - Loos of communication with TCS
I'm getting an intermittant Servise Traction Control warning. I know TCS is Tractio0n Control Sysytem. What are DCM and IPCand what may cause this? Do I have a loose connection somewhere? Please advise. I'm selling my car tomorrow and I want to get this fixed before then if possible. Thanks for your help!
Are these all shown as current codes (no H behind the number)? If so, it could be a loose wire or a ground problem, etc.
In general the 10xx codes can be expected to occur now and then, and can be safely ignored if they show up as history codes... if they show up as current, or get reset when you clear them, then you've got some kind of problem.
