Service traction control
Old Nov 10, 2020 | 10:37 PM
Zachary Maciel's Avatar
Zachary Maciel
3rd Gear
Default Service traction control
Got service traction control signal. I turned vehicle off and back on that got the signal to go away. First thing I did was search this happening and read I should run dic codes. They are
10-PCM P1571 H
28-TCS C1277 H
40-BCM NO CODES
i need to know soon I live in mass and I’m at 82 days into my purchase. If I should bring back please let me know. Can’t have a trap corvette.
Old Nov 11, 2020 | 09:27 AM
bjones7131's Avatar
bjones7131
Mine popped up one time a few weeks ago, turned car off and back on and no more issues. Ran the codes but forgot to document them but hasn't happened since. I would monitor it for several starts and drives and go from there. If codes come back take it in, if not drive on. Weak batteries play havoc on the C5 electrical components and sometime they just have a hiccup. The H as you know are history codes meaning there was a problem in past. Good luck with it.
Old Nov 11, 2020 | 02:04 PM
Zachary Maciel
3rd Gear
Ok thank you. I just can’t replace any of the electrical components for a year and this car was the last year with the discontinued EBCM.
Old Nov 11, 2020 | 03:35 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
10-PCM P1571 H
28-TCS C1277 H
40-BCM NO CODES
If you mean you have a 90 day warranty that's ending in a few days I would bring it back to have it checked out. At least if it fails a little later you may have a case to get them to fix it.
Old Nov 11, 2020 | 03:45 PM
C5MSG2004Vert
10-PCM P1571 H
28-TCS C1277 H
40-BCM NO CODES
To Service traction control
