Check Engine light
Old Dec 5, 2002 | 01:45 PM
Jerryk's Avatar
Jerryk
Default Check Engine light
Can anyone tell me if after hitting the rev limiter, does it cause the check engine light to come on. This happen to me when i had it in 1st and was a little slow in shifting to 2nd in my 98 A-4.
thanks :confused:
Old Dec 5, 2002 | 02:44 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: Check Engine light (Jerryk)
thanks :confused:
I guess the first question is are there any codes present?? Second is, why are you shifting through the gears? If your programming is right it should shift at whatever points you specified in the tuning and at WOT will shift at red line or beyond if you increased your rev limiter.
Old Dec 5, 2002 | 02:59 PM
Duck916's Avatar
Duck916
I hit the rev limited once. It didn't activate the check engine light.
Old Dec 5, 2002 | 04:08 PM
Jerryk's Avatar
Jerryk
Default Re: Check Engine light (sweetcharity)
iT was a open spot in after stop and go traiffic broke loose. The codes i have are C2120,U1064H,P1416HC, P0463H
Old Dec 5, 2002 | 04:16 PM
QUIKAG's Avatar
QUIKAG
Just reset it, it's probably just a false KR reading.
Old Dec 5, 2002 | 07:33 PM
Jerryk's Avatar
Jerryk
Default Re: Check Engine light (QUIKAG)
I know how to reset the codes buts how do you reset a check engine light
Old Dec 5, 2002 | 07:43 PM
ICULUKN-C5's Avatar
ICULUKN-C5
If you reset the code then the light will go out.
Old Dec 5, 2002 | 09:31 PM
sweetcharity
Default Re: Check Engine light (ICULUKN-C5)
:yesnod: :iagree: You can do a search and get the code list and what they are asssociated with.
To Check Engine light
