Coil overs/longitudinal leaf
Are you lowered at all? What suspension/springs do you currently have?
I liked my firm Z51 suspension (which could be rough at times) until I lowered it past where stock bolts would take it. Finally decided to pull the trigger on coilovers simply to get some ride quality back since I want to lower it more.
In general, comfort is going to depend on which coilover you go with and your expectations. As pointed out above, this is a sports car... it's never going to ride like a Cadillac haha
As to the comfort, your mileage may vary. I worked at it for a year with the manufacturer - piston settings, spring rates, etc. Even they said if comfort was what I was after, then probably should have stuck with stock. Geometry changes and ride changes. Just like lowering the car produces a rougher ride. You change the suspension geometry and potentially reduce shock travel.
Not here to try to convince you. I've been through it, you haven't. Give it a whirl. You will always be able to find a buyer for the coils if you don't like them.
You have to increase spring rate and shock damping when decreasing travel to keep from constantly bottoming out a lowered car. So, coilovers on a lowered car won't ride as well as stock at a reasonable ride height. They might be better than stock lowered to the point it's into the bump stops all the time, but won't be better than stock no lowered that far. The car will look cool lowered and that's all the counts for some people.
My car was fully lowered on stock bolts when I bought it. I raised it back up some of the way because it rode like crap. The extra height didn't make much difference in how it looks.
Ride is so subjective it's hard to know what's wrong or if anything is wrong. The first thing to do is checking the ride height of the car.
I wonder if a lot of guys never get their car realigned after lowering it, mine is fully lowered on stock bolts, drove like crap until I could get it aligned, and now it feels pretty much as it did before, not a horrible ride at all.
With longer bolts and Bilstein B8s, bottoming out/hitting bumpstops has never been an issue for me. The "compression" stage is totally fine and is still what I'd consider fairly soft. My problem with ride quality comes from lowering the rear with longer bolts, which basically removes all spring tension when the car "rebounds". The rear basically turned into a trampoline. I'm confident that swapping in coilovers with adjustable damping and ride height adjustment that doesn't alter spring preload or travel whatsoever will create a much better ride all around.
heggsc5 - Bilsteins allow more travel than stock because they don't have the stock type big bump progressive bump stop in them. But, when they hit they will hit hard. Otherwise, your description of what happened on the rear makes little sense. The spring would only be fully unloaded if the car was on the bump stops. Otherwise, it's still holding up most of the weight of the car. Maybe you meant the shocks travelled to close to their end limit so they couldn't control rebound correctly? Saying you need to keep a certain spring preload with a coilover isn't really accurate either. In reality, you want to keep the coilover shock in the appropriate static spot even when adjusting ride height. The spring preload is just what it is to obtain not, not the actual thing you're trying to achieve when setting up the coilover. Those coilovers must allow you to move the mounting point on one end? The part to be careful of with that type of setup is that you don't travel bind any of the suspension components by adjusting it too low.
My description makes total sense if you actually look at the rear spring haha. With longer rear bolts, the rear spring is 100% decompressed while on jackstands (the bolts are totally loose aka zero weight on them). Now imagine that on the road after hitting a bump. Same thing. I was talking about spring preload, not shock. A lot of coilovers adjust the ride height by compressing the spring more. Some coilovers, including the Silvers I bought, adjust ride height by having an adjustable base. So I can adjust the ride height up and down without affecting shock travel, spring preload, or worry about the possibility of any binding. The entire assembly remains the same while you're able to spin it up or down in the bottom mount/cup.
It appears you don't understand how vehicle springs work. There isn't one coilover made where you raise the ride height by compressing the spring or lower the car by decompressing the spring. The spring is always compressed the same amount with the same car weight on it regardless of ride height.
A spring has a spring rate in lbs/in, which says how much it compresses when weight is put on it. Say the spring is 400lbs/in. That means with 400lbs on the spring it compresses 1". With 800lbs on the spring it compresses 2". With 1200lbs on the spring it compresses 3". Easy, right. So, when the weight of the car remains the same and the springs are holding up the car then the springs are always compressed the same amount. It doesn't matter if you crank your spring bolts up or down, the spring is still compressed the same amount when the car is sitting on the springs. Lengthening the rear spring bolts certainly does not remove load from the spring or cause the spring to be compressed less.
Coilovers with adjustable spring perches don't change the coilover compression when the car is on the ground. All that does is lead to the possibility of reaching full extension or compression of the shock if you adjust the spring perch too much in either direction.
