2001 Telescoping Problem
Old Nov 25, 2020 | 03:53 PM
2001C5Corvette's Avatar
2001C5Corvette
1st Gear
Default 2001 Telescoping Problem
Hello,
New forum member here. Hope there is some help for this..
2001 Vert
Telescoping worked intermittently for years and now is stuck in forward/in position. Switch isn't broke. Tried the "reset" procedure (push 8 and hold both ways) to no avail. Can hear the relay in the control module under seat clicking. Had a few LCDM codes though all were history...cleared codes and tried procedure again...no dice. Memory buttons 1 & 2 function properly. All the seat controls function properly. Tried reset with DIC Easy Entry both on and off.
ANY IDEAS??
Also can only relearn 3 Tire pressure sensors...the LR won't chirp horn and DIC shows XXX..
Thanks in advance!
