battery,lights issue
Old Nov 27, 2020 | 06:58 PM
6Gxray's Avatar
6Gxray
Cruising
Default battery,lights issue
rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old Nov 28, 2020 | 08:53 AM
rrwirsi's Avatar
rrwirsi
If not already tried, do what I do when my computer does strange things. Shut it off, unplug from wall (disconnect ground wire of battery), wait 1 minute, and reboot (connect ground wire back to battery). Worth a try.
Old Nov 28, 2020 | 09:07 AM
Ed Ramberger's Avatar
Ed Ramberger
Sounds like Twilight sentinel is on. Go into the DIC and check and turn it off if it is.
Old Nov 28, 2020 | 12:28 PM
6Gxray's Avatar
6Gxray
Cruising
yes it was off thanks
Old Nov 28, 2020 | 12:30 PM
6Gxray's Avatar
6Gxray
Cruising
yea did that trying to reset it thanks anyway
Old Dec 2, 2020 | 03:59 PM
grinder11's Avatar
grinder11
Did you figure it out yet?
Old Dec 5, 2020 | 12:33 PM
6Gxray's Avatar
6Gxray
Cruising
Nope,I think i am going to have to have the computer flashed .Its got to be a computer problem.
Old Dec 6, 2020 | 08:56 AM
Ed Ramberger
You didn't install LEDs while you were doing the work did you?
Old Dec 6, 2020 | 08:58 AM
oharal's Avatar
oharal
I assure you the code on any module didn't change itself while the battery was disconnected.
Old Dec 18, 2020 | 05:28 PM
6Gxray's Avatar
6Gxray
Cruising
nope
Old Dec 18, 2020 | 05:46 PM
6Gxray's Avatar
6Gxray
Cruising
Default update 300$ rookie mistake
So I know better than this my stupidity,but in my nervous anticipation to get my motor cranked up,and check for leaks.I had the battery hooked up before I even realized the damage had been done.I accidently hooked the positive terminal up first then the ground.Never Never do this I was lucky just the headlamp control module kind of burnt up. The module still would activate the motors to go up although not down.I had to take the car to a automotive electrical tech.
Old Dec 18, 2020 | 06:23 PM
oharal's Avatar
oharal
What happened? The procedure of connecting the positive first then the negative is the proper procedure...
Old Dec 18, 2020 | 06:30 PM
Smoken1's Avatar
Smoken1
Been doing it that way for many years
Old Dec 18, 2020 | 06:35 PM
oharal's Avatar
oharal
Yeah you only do it the other way once....ZAP
To battery,lights issue
