Headlight Actuator Replacement
Old Dec 3, 2020 | 01:28 PM
mellowyellow2001's Avatar
mellowyellow2001
Default Headlight Actuator Replacement
Hello All, I need to replace my headlight actuators on both sides and am slightly confused. I have a 2001 vert, 6 speed manual with the auto headlight feature. In my searches on-line for the actuators I see that there are 2 options available - one with 2 wire and one with 3 wire. I'm not sure which ones I should purchase. I would appreciate some input.
Old Dec 3, 2020 | 01:38 PM
rjacobs's Avatar
rjacobs
do your motors work?
Do you just need gears?
I believe its fairly rare for the motors themselves to go out... but the gears... thats another story.
Old Dec 3, 2020 | 04:39 PM
mellowyellow2001
The driver side motor is dead (had the unit replaced over a year ago). Passenger side motor is good, gear is bad. Do I need to order a 2 wire set-up or a 3 wire set-up.
Old Dec 4, 2020 | 12:51 AM
rjacobs's Avatar
rjacobs
i dont see anything pertaining to 2 or 3 wires in my parts searches only left and right... so I cant help you there.
Old Dec 4, 2020 | 10:56 AM
bjones7131's Avatar
bjones7131
I replaced my drivers side on 03 Z06 and no mention of wires when i ordered from rockauto. How many wires on your existing set up? Go with that if it matters.
Old Dec 4, 2020 | 11:20 AM
bjones7131's Avatar
bjones7131
I think early cars actuators were bolted together instead of glued and much easier to change gears. My driver headlight would pop up when I selected park lights and was grinding so I just replaced the entire motor 70.00 and turned the bumpers over and all was well. I seldom drive at night so should last for a long time.
To Headlight Actuator Replacement
