Melling Oil Pump Failure
No word yet as to how Melling will respond.
correct O-ring installation, correct O-ring size, oil pump relief valve spring tension, and relief valve moving freely in the relief valve bore. Even reputable companies get a batch of bad springs from time to time, whether they're valve springs, or oil pump relief springs. Melling, being a reputable company, would be no exception. I hope this helps.....
There wasn't a whole lot of forensic examination with the failure of the OEM pump. The first Melling pump that failed was actually working as expected in terms of pressure but there was a loud "knock" sound emanating from the pump. Melling covered under warranty without issue, and also paid for the shop time to make the replacement. We gambled on any further damage to internals of engine and lost, which lead to a rebuild. Because of this damage this second pump was not used on the rebuild.
The engine was then completely rebuilt prior to the install of the next pumps. At start up the pumps two and three performed in the same way. Cold start, at idle, 55+#'s of pressure. As engine temp increased, oil pressure decreased down to 13#'s. Pressure readings taken from top and bottom of engine and were within 1# on gauge. At Melling's insistence that the pumps could not be the issue, the engine was removed and rotating assembly disassembled. Bearings were taken apart and measured and were all with the builder's expected tolerance. Builder is a very reputable shop and given the fact the pump performed the same on the dyno as on the engine tells me that the issue is 100% with the pump. It was just unfortunate that the pumps weren't checked on dyno prior to engine being removed for examination as it would have save a lot of headache, and shop time.
hopefully this fills in some blanks...
Last edited by grinder11; Dec 11, 2020 at 09:17 AM. Reason: Spell and more info to add
I'm certainly not taking a cheap shot at the OP, but seriously, three bad oil pumps, all in a row?
Last edited by grinder11; Dec 11, 2020 at 12:55 PM. Reason: Spell and more info to add
OP, do yourself a favor and have a oil pressure sensor relocation kit installed, and put a mechanical gauge on it to see what the pressure truly is.
I do appreciate the assistance, but I don't have the engine as it's at the shop that built.
To answer a couple of the questions:
it's not three pumps in a row, it's 3 out of 4, not that that's anymore likely. The original failed pump was a 10295 which was replaced with another 10295, and it was working fine for two months until the residual damage from the first loss of pressure made itself known. Builder wanted the high volume pump so a 10296 was installed with the rebuild. Two of those then failed in the same fashion.
All bearings are new with the rebuild and checked measurements are as expected. The barbell is in place. Given that the shop's pump performs without issue tells me that neither of these possible culprits are at issue.
The pump dyno testing was done at the engine builder's shop. It was their "good" pump that was compared to my failed pump. Their dyno uses a separate device to run the pump; the oil pump is not bolted to the block, which takes the oil pickup and O-rings out of the equation. The block is heated with circulating hot water to get the block to operating temp. The pump is driven to push oil through the engine where pressures are measured at the filter (crank pressure) and at the top of the block (cam bearing pressure). Their good pump maintained pressure throughout the engine temp range. The block is then cooled and test started over again with my oil pump. My pump performed the same on the dyno as it did when installed in the car; 55lbs with cold block and 13lbs with the block at operating temp.
I don't know if they've inspected the pump bore or spring pressure, not sure it matters at this point.
The shop’s good pump is also a Melling high volume.
Sorry, no pics of the pump dyno
Sorry, a little attempt at humor to lighten the mood. Anyway, early on in the LS history, GM had some bad pumps, where the relief valves were sticking open. Resolved long ago. As Ron said, go with the new GM pump. I hate to advise against a Melling, as they have a great track record, and I've used them many times, never once a problem. It sounds like the engine had checked out OK,, and gone over with a fine tooth comb. I suggested awhile back to check EVERY PUMP DIMENSION. Has the pump been checked as thoroughly the engine? You may be at the forefront of a bad pump production run. Nobody has that answer yet, but if your motor has fine oil pressure with the shops Melling unit, what else could it be besides bad pumps? Take a video of your motor with the shops pump, then change nothing except the pump, take another video of that, and send them both to Melling, as a "before and after" situation. I would think Melling would be most interested in these videos!! Years ago, I made up something myself to spin the LS pump with a drill motor. The oil pump drive hub was put on an ID grinder, and I ground around .002"-.003" out of it, until it spun freely on the crankshaft. Oiled up the crank and ID of the altered hub, and then spun it with a drill motor. Great priming tool......Last edited by grinder11; Dec 13, 2020 at 01:22 PM.
Sorry for your trouble, but I'm in for the information when you get it.
