How do you remove red threadlocker?
Old Dec 7, 2002 | 05:37 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default How do you remove red threadlocker?
Old Dec 7, 2002 | 05:39 PM
rgregory's Avatar
rgregory
Default Re: How do you remove red threadlocker? (Bluewasp)
Alcohol should get it off.
Old Dec 7, 2002 | 05:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You mean remove a bolt that was assembled with red loctite? You need to heat it. Propane handheld torch should do the trick. You will see it smoke, and it will have a very sweet smell to it when it burns off. It should disassembe easily then.
One good point to note here, is not to use the red stuff if you can't use a torch to remove without damaging anything. The blue stuff usually will do the trick, but doesn't require heat to remove.
:cheers:
Old Dec 7, 2002 | 05:47 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: How do you remove red threadlocker? (Y2Kvert4me)
:cheers:
thank you!! :)
Old Dec 7, 2002 | 06:11 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Robert- Once you get the bolts, out, you will need to clean the threads if you are going to reuse the bolts. A bench grinder with a wire brush, or a wire brush attachment for your drill motor will work great. If there is a bunch of the stuff on the bolt, you might want to consider chasing the inside threads with the appropriate size tap. **** maybe, but it's always easier to do it correctly one time than it is to do it twice. :D
Old Dec 7, 2002 | 06:22 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: How do you remove red threadlocker? (CHJ In Virginia)
The threadlocker was on my Brembo caliper studs... here's a pic. the heat melted the red threadlocker.
[Modified by Bluewasp, 6:26 PM 12/7/2002]
Old Dec 8, 2002 | 08:30 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
:iagree: Good tip!
Tom
To How do you remove red threadlocker?
