PCV Hose Assembly
Old Dec 21, 2020 | 04:28 PM
ghopper141's Avatar
ghopper141
Default PCV Hose Assembly
As some of you are aware, the rubber GM used to connect the PCV hose assembly pieces to each other is pretty soft, and has a tendency to deteriorate over time. I found this out the hard way while replacing the oil pressure sensor on my 02 Corvette this weekend. While searching for the three-way connector I needed, I found it wasn’t available, and most posts I read recommended biting the bullet and spending the $135 + / - the new assembly costs.
I didn’t have any extra cash lying around for this, so I came up with my own solution, and it costs me less than $10 at my local NAPA Auto Parts store.
I purchased a 3/8 “Y” vacuum fitting, part number CRB 2638, and a foot and a half of 3/8 inch rubber fuel line. I had fuel line left over, but I used part of it to replace another vacuum line that had started to crack, and still had more to toss in my toolbox for later.
Steps: I cut three pieces of fuel line, roughly 2 1/2 inches in length, attached them to the Y fitting, then attached the existing PCV piping to the new assembly. I had to cut a couple of inches off the plastic PCV pipe end to make it fit in the car, as the new assembly was now longer than the factory one, but it’s air tight, doesn’t leak, and it was a lot cheaper than a trip to the dealer.
I hope this helps anyone else who might run into this problem, because it saved my butt, and didn’t hurt my wallet.
Per request, I’ve added a marked up photo of a similar PCV assembly that more closely resembles what I did to mine. This one is for a 4th generation Camaro, but is very close to the C5’s. FYI - the small rubber line on the top of this photo is the same one I replaced that was cracking. It’s the end that attaches to the passenger side valve cover.
Old Dec 21, 2020 | 07:05 PM
vidvet02's Avatar
vidvet02
Thanks for good write up. i had same problem on my 02, and purchased a used hose setup for mine. I didn't even think about this. Thanks again.
Old Dec 21, 2020 | 07:12 PM
DECON BLUE's Avatar
DECON BLUE
Great McGyver moment !! Pics would of been nice 👍
Old Dec 21, 2020 | 08:40 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Thanks for the info. Mine I'm sure is getting to the point of needing repair also so I'll keep this info for future reference.
Old Dec 21, 2020 | 08:42 PM
Moved to C5 Tech.
Old Dec 21, 2020 | 08:52 PM
ghopper141's Avatar
ghopper141
Sorry, I thought about it afterward, but I was too wrapped up in the oil pressure issue and making sure I didn’t have another problem other than a bad sensor. I’m not sure I could have adequately documented it with photos. I might try to draw something up later and add it to the post.
Old Dec 21, 2020 | 09:05 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Heh. I just got a new one of those earlier this year.
That one hurt. lmao
To PCV Hose Assembly
