Rear end noise
Old Dec 25, 2020 | 08:31 PM
Joseglenn Vargas's Avatar
Joseglenn Vargas
Default Rear end noise
Hi fellow corvette enthusiast. I知 hearing a scraping noise in my rear end of my 01 z06. Can hear it when windows are closed in the cabin and I知 I知 only going about 15 mph.
Old Dec 25, 2020 | 08:41 PM
Joseglenn Vargas
Originally Posted by ~Josh
Could be brake pads low.
Have you visually checked for debris around your wheels/axles and checked the brake pad level?
so my mechanic said I have 50% life left and I hear the scarring noise when I知 not even braking. More of like no throttle movement.
Old Dec 25, 2020 | 09:40 PM
Joseglenn Vargas
Did the mechanic physically remove the wheel to check the inside pad as well?
Seeing 50% looking through the wheel spokes can give a false impression as the inside pad (where the piston pushes) may have 10%.
not to sure actually, but I do feel a little thudding when breaking at speeds higher then 50mph as well
Old Dec 26, 2020 | 12:33 AM
Moved this to C5 Tech.
Old Dec 26, 2020 | 12:55 AM
sloopdawg's Avatar
sloopdawg
I've always been told (and try to do so myself) that about every six months or so you should remove your brakes and clean and grease them no matter if the pads and or rotors need changing or not
hopefully you find and your problem
let us know what you find
Old Dec 28, 2020 | 10:42 PM
Joseglenn Vargas
replacing my rotors and pads soon and will update after
To Rear end noise
