Drives door/window switch
Old Dec 30, 2020 | 10:00 AM
bjones7131's Avatar
bjones7131
Default Drives door/window switch
My door/window switch works but have to push pretty hard on window control button to operate. Any way to remedy or repair besides replacing entire switch which I am not opposed to, fairly cheap but if there is something I can do to fix the switch I'll give it a try. Thanks
Old Dec 30, 2020 | 10:47 AM
Autoeng's Avatar
Autoeng
I have a OEM switch with memory seat that works perfectly but the cover is torn. If you could remove the cover from yours and replace I would give it to you for shipping costs and a fiver. Probably be less than $10
Old Dec 30, 2020 | 11:00 AM
bjones7131's Avatar
bjones7131
Which cover is torn, the window buttom I assume. Not sure how to install cover. Could U shoot me a pick? thanks
Old Dec 30, 2020 | 07:29 PM
Autoeng's Avatar
Autoeng
I don't know if the cover can be removed or not. Looks like it is attached with glue
Old Dec 30, 2020 | 07:39 PM
bjones7131's Avatar
bjones7131
Yea I agree, thanks
To Drives door/window switch
