Cover alignment confusion
Old Dec 31, 2020 | 10:38 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Default Cover alignment confusion
Im confused. When installing a new timing cover do you install the front seal into the cover and then install and align the cover or do you align/install the cover first and then install/align the seal afterwards??? I also dont know how many alignment tools i need, there are a few different ones.
Thanks all
Old Dec 31, 2020 | 11:17 PM
oharal's Avatar
oharal
You need the tool that aligns the center of the hole in the cover with the center of the crank axis. The tool basically takes up the space where the seal goes so you have to install the cover properly aligned using the tool then press the seal into the gap between the crank and the cover.
Old Jan 1, 2021 | 12:08 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
^^^ thank you
Old Jan 1, 2021 | 01:57 AM
1BadLS6's Avatar
1BadLS6
The videos in the following link are good how-to's. The Sac City tools make it super easy.
https://www.saccitycorvette.com/AlignItTools.html
Old Jan 1, 2021 | 08:25 AM
CinciZ06's Avatar
CinciZ06
And there are multiple types of alignment tools. You definitely want the type described above that allows you install the seal after. I used Saccity tools for the front and rear cover and they were phenomenal.
Old Jan 1, 2021 | 09:56 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Ok i just ordered the front cover tool. I dont think i should need the simulator. Thanks guys
To Cover alignment confusion
