help...i m stuck
Old Dec 8, 2002 | 11:58 AM
danhC5's Avatar
danhC5
Cruising
Default help...i m stuck
I DID IT. Thanks all for quick respone.
front lowering bolt...when you take it out do cut it from the bottom? there is a piece of washer welded to the bolt. Please let me know asap.....thank
[Modified by danhC5, 7:32 PM 12/8/2002]
Old Dec 8, 2002 | 12:13 PM
Viprklr's Avatar
Viprklr
Default Re: help...i m stuck (danhC5)
Not usre if I understand your question, but you don't cut the bolt. You trim the washer/bushing portion off. Just make sure you cut the same amount on each side. :cheers:
Check this link if you haven't already:
https://www.corvetteforum.com/techti...D=90&TopicID=1
Matt
[Modified by Viprklr, 11:14 AM 12/8/2002]
Old Dec 8, 2002 | 12:19 PM
danhC5's Avatar
danhC5
Cruising
Default Re: help...i m stuck (Viprklr)
right...trim the bushing....but from the bottom right? there is a piece of metal plus bushing from the bottom too
Old Dec 8, 2002 | 12:33 PM
Viprklr's Avatar
Viprklr
From the bottom. The pictures in the tech section show it very well. Leaving 1/3 of the bushing will really lower the front.
To help...i m stuck
