Power Window Problem
Old Jan 2, 2021 | 07:27 PM
gnost's Avatar
gnost
Default Power Window Problem
I just purchased an '03 Z06 and the window will only go up and down all the way if the door is open. When the door is closed, the window will only go half-way down; it will go up.
Any help appreciated.
Best,
SM Ross
Old Jan 3, 2021 | 09:26 AM
bjones7131's Avatar
bjones7131
following
Old Jan 5, 2021 | 12:15 PM
grinder11's Avatar
grinder11
Best,
SM Ross
Sounds like the connectors in the doors "accordian" rubber boot. Bill Curlee has an excellent electrical stickie on this, and many more problems in other circuits. It is long, but it's also VERY informative. Do you have any codes, like LDCM, which is "Left Door Control Module"? If you hold down the "options" button while pressing and releasing the "Fuel" button 4 times in less than 10 seconds, your codes, if any, will show on the DIC. Please post your codes, if any.
Old Jan 6, 2021 | 06:45 AM
gnost's Avatar
gnost
Default re: Power Window Problem
Thanks for your reply, Grinder11. I will check out the Stickies you referred to.
Yes, I do have codes. They are:
B2282H-Battery #1 Fault
B2284H-Battery #2 Fault
U1064-Loss of Communication with BCM
Thanks,
SM Ross
Old Jan 6, 2021 | 09:29 AM
c5racer88's Avatar
c5racer88
Battery tested ok? Bad batteries have caused lots of strange symptoms. Get an AGM with the highest ratings. I used an Interstate AGM MTZ-78. Its rated at CCA800, CA1000, RC125.
To Power Window Problem
