Clutch has had it
Old Dec 8, 2002 | 05:28 PM
scool93535's Avatar
scool93535
Default Clutch has had it
At the track yesterday I found the clutch slipping during power shifts.
See http://forums.corvetteforum.com/zerothread?id=448453 for all the gory details.
Looks like it's time for a new one. I have a catalog from one of our CF vendors showing a McCloud aluminum flywheel & clutch assembly package ~$1,400.00. Does this sound like a reasonable setup, (see sig for mods), for my car?
I'd like to go to an aluminum flywheel so the motor can spool up quicker. I realize that I'll be trading some torque but, I figure if I need more torque on the launch I can simply bring the R's up higher.
Given my mods are not that major, I could probably get away with a Z06 clutch assembly from the same vendor for ~ $369.00, however, I intend to add MT ET Streets soon so I'm a little concerned that I may need the heavy duty assembly.
Also, I"ve never experienced any clutch problems associated to the hydralics. Can I leave the master and slave in place and just replace fluid and blead?
Any stick shift guys out there have recommendations for clutches. The $1,400.00 is about my limit for this repair.
Thanks, :cheers:
Old Dec 8, 2002 | 11:25 PM
see5's Avatar
see5
Default Re: Clutch has had it (scool93535)
I have the 02 Z06 clutch and it has been great. Am doing intake ,cam,heads and 390 with the expectation that it will still hold.
Old Dec 9, 2002 | 09:46 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Clutch has had it (see5)
i have a spec stage 3 carbon fiber with alum flywheel. It was under 1400 installed. I launch on the bottle (over 500 RWHP) on ET Streets with no slippage.
To Clutch has had it
