2000 C5 covertible
Old Jan 7, 2021 | 07:08 PM
Lpga's Avatar
Lpga
Default 2000 C5 covertible
Oil pressure gauge stuck on 80psi. Is it the sensor?
Old Jan 7, 2021 | 07:25 PM
Smoken1's Avatar
Smoken1
Yes
Old Jan 7, 2021 | 07:52 PM
Lpga's Avatar
Lpga
Originally Posted by Smoken1
Yes
thanks for that. My other problem is the fan switch inside only blows when it is on 5. Lower numbers 1 2 3 4 hardly blow at all. Is this the resistor?
Old Jan 7, 2021 | 08:10 PM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
Well I would say that your problem blows but it doesn't so it's a problem. Sorry for the bad humor but I would venture to say that the blower motor resistor is bad. It's a cheap part if it's manual control but kind of pricey if it's auto temp control.
Old Jan 8, 2021 | 07:33 AM
Lpga's Avatar
Lpga
Default Humor is good in this day and age!!!
Thanks for the help. Kinda figured that it was resistor.. watched a video of replacing it. Doesn't look to complicated. Again thank you.. Ingrid
Old Jan 8, 2021 | 11:56 AM
grinder11's Avatar
grinder11
I'd like to give my 2 cents on the sending unit. DON'T buy OEM! In most cases, OEM stuff is as good, or better than, aftermarket stuff. That said, I have owned my 2000 Vert for almost 18 years. So I've been thru my share of sending units. I've even had them fail showing ZERO pressure! I've never had a factory sender go more than 3 years, tops. They either read high, low, or start leaking. GM needs to seriously consider sourcing a different manufacturer for oil sending units. Buy a real good aftermarket sender from NAPA, or other good Auto Parts Store. I finally went with an El cheapo aftermarket sender 4 years ago. Still works fine, doesn't leak, and has lasted longer than any OEM unit I've had, so far. Bought it at O'Reilly's. Hope this helps
Old Jan 8, 2021 | 05:45 PM
Lpga's Avatar
Lpga
Default Oil gauge sending unit
thanks for the info. Will go to NAPA to get one.
Old Jan 8, 2021 | 06:48 PM
Adwest52's Avatar
Adwest52
Me confused? Please explain.
Old Jan 9, 2021 | 03:14 PM
Moved to C5 Tech.
Old Jan 10, 2021 | 09:52 AM
grinder11's Avatar
grinder11
Please re-read my post. I said in MOST cases OEM stuff is pretty good stuff, but NOT when it comes to C5 oil senders.......
Old Jan 10, 2021 | 11:20 AM
Lpga's Avatar
Lpga
OK got it it.. thank you for your advice..
To 2000 C5 covertible
