Help With Remote Start!
Old Jan 9, 2021 | 11:05 PM
Jory Johnson's Avatar
Jory Johnson
Default Help With Remote Start!
I have a 98 Corvette that I got sick and tired of the stock key fob loosing memory and not working. decided to go with an aftermarket security/remote start.
after following the given instructions i am very confused as to the issues i am having....
When Its ALL CONNECTED and i try to start the car with the remote it only flashes the parking lights 3xs.
If I UNPLUG all the (non ignition) wires like the door locks hood pin then the car will START for a few moments and then shut off....if i leave the key in the Ignition the car will start just fine with the remote as long as the door locks hood pin ets are not connected...
Compustar CM-900
Idatalink Compustar BLADE- Idatalink Compustar BLADE-
for the Ignition bypass... ]
also i have the DroneMobile - X1 LTE Vehicle Alarm System
when i start the car with the app (with the door locks and hood pin disconnected the app starts the car and then says its successful even after the car shuts off the timer still acts like the car is running)
Ive flashed and updated the units
Ive double checked and triple checked all my connections are correct
anyone have any idea wtf is going on?
I would just bypass the vats by wiring in a resistor to the remote start but I want the door locks etc to work...
any help would be greatly appreciated
Old Jan 16, 2021 | 04:46 PM
Jory Johnson
Anyone?
